Old 06-01-2021, 04:20 PM
X66 714's Avatar
X66 714 X66 714 is offline
Default 5460346 master cylinder I.D. help please
I aquired a 5460346 master cyl core some time ago & I can't determine it's usage. The pad is pitted badly but it looks like it has a "P". It's bore is 1.125". Both ports measure .500 with a dial caliper. It has 2 bleeder screws. There is a casting of D4. The piston is real shallow (3/8 or so) as manual disc brake cars are. Any help out there? Thank you, Joe
Old 06-01-2021, 05:06 PM
cook_dw's Avatar
cook_dw cook_dw is offline
Got a photo of the stamp?
PG is corvette.
Old 06-01-2021, 06:48 PM
X66 714's Avatar
Let me see what I can do Darrell...Joe
Old 06-08-2021, 02:24 AM
Here is the PG stamp on the master cylinder on my 71 Corvette.
Manual brake cars use a DC master - 67-early 72 is the same master cylinder.
Casting doesn't change after that however they are stamped on the first boss with the assembly stamp and date.
The machining or assembly date is on the first boss with the line coming out.
If there is not a jullian date (formatted: LAST digit of year followed by the day 001 -365) it is from a 67-69
Old 06-08-2021, 12:00 PM
X66 714's Avatar
Thanks James. There's no date & that pad is too pitted to determine anything....Joe
Old 06-08-2021, 12:08 PM
cook_dw's Avatar
Best I can tell it’s either a P, S or 8 but it’s too far gone to know for certain.
X66 714 (06-08-2021)
