Old 08-13-2021, 04:57 PM
TMagda's Avatar
TMagda TMagda is offline
Default Garage Floor Epoxy?
Can anyone recommend a higher quality garage floor epoxy suitable for DIY? I have seen many bad reviews of the big box store stuff and do understand prep is everything. I can also tell they almost all fail over time. I have seen 2 well known car guys, who both do things right, complain online about their floors failing. I just moved and my new garage floor is painted and slippery as ice. Need to correct ASAP. Thanks in advance.
The Following User Says Thank You to TMagda For This Useful Post:
seventieshow (08-13-2021)
Attachments - The Supercar Registry Resized_20190814_172559.jpeg.jpg Resized_20190719_144501.jpeg.jpg FDB9FF3B-B217-4433-94D9-901360F6F3A5.jpg F99AE6F4-4CE8-44A7-AE63-D9D9DDE234D2.jpg
Old 08-13-2021, 05:14 PM
RogerD's Avatar
RogerD RogerD is offline
Add a topcoat (best guess on match) with “non slip additive” in it
You are stuck with what’s been applied, most likely not epoxy
Do the prep
Old bare floor/new bare floor (new concrete cure 60~90 days)
1. Clean oil spots with solvent, lacquer thinner, acetone etc
2. Wash with hot soapy water
3. Etch with Muratic acid to neutralize active alkali
4. Flush with clean water, dry several days then apply quality 2 component epoxy
Pittsburg, Benjamin Moore, Pratt & Lambert, maybe Lowe’s
This is old school, P&L commercial recommendation, new stuff may vary
Worked for P&L about 15 years
Not up to date on new gen eurathane floor paints, read the label
Old 08-14-2021, 04:10 PM
L72copocamaro L72copocamaro is offline
You could also have the floor sand or shot blasted and start over.
Old 08-15-2021, 12:09 PM
southernfriedcj's Avatar
The GarageJournal.com actually has a garage flooring subforum. They have beat the subject to death. It's the end all of garage flooring/coating.
There are also manufacturers of coatings that post on the forum.
The Following User Says Thank You to southernfriedcj For This Useful Post:
dykstra (08-16-2021)
Old 08-16-2021, 03:15 PM
TMagda's Avatar
Thanks. I was planning to grind it and start over. I'll check garage journal.
Old 08-16-2021, 04:18 PM
Crush Crush is offline
I agree with GJ recommendation
I went w staind concrete w an epoxy clear in one area and went with racedeck in another
Happy w both
The Following User Says Thank You to Crush For This Useful Post:
69M22Z (08-16-2021)
Old 08-16-2021, 05:55 PM
Most of the big box kits come with citric acid to etch ---
I used the rustoleum epoxy kit I tossed the citric and used muratic make sure to follow the instructions religiously - I had to wash the floor with a pressure washer 2 times to get rid of the residue. Make sure to do the test using a piece of plastic taped down to test the moisture in the floor.
FWIW My father dropped a tractor scrape blade from 36" onto my floor and it didn't chip the epoxy. I have had one place to release less than 1" square where I left battery acid on the surface -- and it pulled the floated concrete top off with the epoxy.
I used the valspar grit additive and did not use the colored chips in mine as I wanted a light color which offered a contrast to bolts etc dropped on the floor.
RogerD (08-18-2021)
Old 08-16-2021, 06:25 PM
James; how about some pics?
My only beef with racedeck is that I want to be able to wash the floor from time to time and just squeegee it off. Spills are inevitable for me (maybe I am just a klutz).
Old 08-16-2021, 06:39 PM
Steve Shauger's Avatar
Administrator
I used a Home Depot epoxy product 20 years ago, but dont recall the name. I recently thoroughly cleaned and sanded the floor and applied the rustoleum( 2 months ago). Looks great but don't know about durability at this point.
www.yenko.net
www.vintagecertification.com
Old 08-16-2021, 07:52 PM
The area I use the racedeck is an area I don’t work on cars. I know you can get the RD in solid large squares that is easy to clean from what I understand.
The epoxy brand I used is Ghostshield and is a 2 part process. I have been very happy with it
The pics show the floor in the cleaning process and then sealed
L_e_e (08-21-2021)
