Solo Smokey Update Okay found some super cool Camaro history!
Rumor has it that Chevrolet came out with a 3x2 manifold for Trans Am Racing and then the project was scrapped. They were working on this before the first 67 Camaro was made Well I can now document this I pulled off the manifold on my 69 Z28 that previous owner Larry Schreib bought it off of Smokey Yunick himself I flipped over the manifold and could not believe it is dated 2/9 /66 it's all true case solved! Thanks in advance Bill Fowler / Solo Speed Shop |
The Following 13 Users Say Thank You to solospeedshop For This Useful Post: | ||
1967Z28 (10-17-2021), 60sStuff (10-18-2021), dykstra (10-19-2021), John Brown (10-17-2021), L_e_e (10-17-2021), olredalert (10-18-2021), PeteLeathersac (10-18-2021), SS427 (10-18-2021), Steve Shauger (10-17-2021), Tenney (10-18-2021), Tracker1 (10-17-2021), Xplantdad (10-18-2021), YenkoYS-199Stinger (10-18-2021) |
That is way cool! I had read about those somewhere and had always wondered if any/how many had been made. Thanks for sharing!
While you have the manifold off it is a good time to clean it, but don't beadblast it.
I mentioned Dry Ice blasting on Facebook....
That is really cool. Thanks for sharing. I use plastic media frequently to clean parts like this. It take off the dirt and surface corrosion without altering the finish.
Jason |
Vapor blasting is the way to go these days. David Beem is a site sponsor here and has the latest apparatus setup for proper cleanup.
You can contact him through his bodyshop I think? https://fixautousa.com/location/colorado-springs/
I like solid lifter cars, big cams and cars w/ 3 pedals in them. ![]() |
Why would they use a 3X2 setup for Trans Am Racing instead of 2X4?
![]() Quote:
It seems like the fuel injection off the C2 327 Vette would have been a better choice for racing. I thought both of these systems were at least ten year old tech at the time. ![]()
Rob 1969 Camaro Z/28. Norwood 02D. Lemans Blue |
The Following User Says Thank You to rlw68 For This Useful Post: | ||
Lee Stewart (10-18-2021) |
They didn't.
The 3 x 2 manifold was never released to production and is not listed in the SCCA T/A Homologation documents for the Z/28.
Just because it wasn't used doesn't mean it wasn't under consideration. Engineers try things to see what works best. The 3x2's must not have come out on top.
Personally, I used to run two 650 cfm Holley two barrels on a cross ram manifold in an IHRA drag class because the class record was softer than it was with a single four barrel. Rule books were meant to be read, whether it's Trans Am or drag racing.
...................... John Brown This isn't rocket surgery..... |
