Old 12-03-2021, 12:38 PM
earntaz earntaz is offline
Default Seat belt guides
On my 71 Nova with bench, there are seat belt "guides" that feed the belts up through the seat. They are made of plastic and hold the belt/buckle from the floor up to the buckle.
Does anyone know where these items can be sourced/obtained?
Thanks ... Craig
Attachments - The Supercar Registry 20211203_173906.jpg 20211203_151432 (1).jpg 20211203_151422 (1).jpg
Old 12-03-2021, 12:58 PM
AFAIK, they are reproduced by no one. Used seems to be the only choice, and finding decent used ones is not easy.
Bill Pritchard
earntaz (12-03-2021)
Old 12-03-2021, 02:11 PM
hogdaddy hogdaddy is offline
Have any pics of the guides?
Old 12-03-2021, 07:50 PM
MarcDant's Avatar
MarcDant MarcDant is offline
Default benchseat seat belt guides
Here are top and bottom pics.
Old 12-03-2021, 08:41 PM
Thanks - I have those pieces ... need the "tubes" the seat belts go through from the attach point to the buckle ...
Old 12-03-2021, 10:05 PM
MarcDant's Avatar
Default bench seat seat belt retractor guide
Got,cha you must be referring to the seat belt retractor cover , the hole assembly has to be replaced because the steele buckle is wider than the opening in the plastic cover unless you remove the buckle and resew it. This is a replacement for my nova in the pic below .
The Following User Says Thank You to MarcDant For This Useful Post:
earntaz (12-04-2021)
Old 12-04-2021, 01:32 PM
Unreal Unreal is offline
The retractor cover on the 69 Camaro is a little different, but I was able to remove and reinstall it by heating the cover in hot water, making it much more pliable. As I recall, it was still a challenge, but doable.
