375 HP 396 MQ code 1968 short block:
Block .030 Crank Std Std cross drilled 6223, no problems 3/8 dimple rods, no problems TRW L78 replacement piston L78 Harmonic balancer L78 Timing chain cover L78 oil pan L78 rocker arms L78 pushrods L78 Valve covers Deep grove lower pulley Engine is in very good shape with ZERO rust issues, and pristine code (MQ). Can be cleaned honed and reassembled. Short block 2600.00 OBO. I also have the 840 heads with out a million valve jobs, but need them for another project but could possibly be talked out of them. All parts listed are original to this engine. |
What is the casting date and build date and vin?
The Following 2 Users Say Thank You to luzl78 For This Useful Post: | ||
Maxsg1973 (07-29-2023), PeteLeathersac (07-17-2023) |
323 block casting, I need to get it out from the bench it sits under and I will post the date code, I do need to have the vin run.
Sold
