I’ve got an M20 Muncie in my 67 Camaro. I bought it completely rebuilt from a reputable builder and it’s got around 8-10k miles on it. It’s currently behind a 525 HP 406 small block. My problem is when I am in 3rd gear, and I decelerate while leaving the trans in gear, it pops out of gear. What would be causing this to happen? It’s very annoying and I want to fix it.
Thanks.
Andy 1967 Camaro 406 4 speed 1969 C/10 383 5 speed 1969 D300 318 4 speed 1969 Super Bee 383 4 speed 1972 K/5 350 Turbo 350 1972 Duster 340 727 1974 'Cuda 340 4 speed |
![]() Quote:
The Following User Says Thank You to Jimlt4383 For This Useful Post: | ||
Andy (08-06-2023) |
I suggest inspecting the bushings on the ends of the 3-4 rod for any wear or abnormality. Check the fastener at the shift shaft for any wear or looseness that allows the arm to move on the shaft. Also, that the adjustment is still correct. Components seat in and can be off enough that the 3rd gear slider may not be traveling far enough to fully engage the keys in the hub in the detent in the slider to help keep it engaged. Do the simple stuff first before looking at an internal cause.
Thank you both for your feedback. I will put the car on the lift and begin the inspection process. I’ll post back with what I find.
Send it back to the builder.... Not a external problem, internal that should have been addressed on the rebuild..
I agree, definitely an internal issue with the 3rd gear synchronizer assembly or the small teeth on the 3rd gear. Bill
The Following User Says Thank You to Big Block Bill For This Useful Post: | ||
L78_Nova (08-08-2023) |
I spoke to Paul Cangialosi yesterday and sent some pictures of the trans to him and he said the issue was the prior builder of the transmission used a locking third gear with a non locking slider. He also recommended hardened hubs, new sliders, and new shift forks. I’ll post some pictures when I revise receive the parts and start the tear down process.
The Following 4 Users Say Thank You to Andy For This Useful Post: | ||
Andy,
Has this always been an issue or is it fairly new? I agree with Mitch. If it is not going all the way into gear then it could pop out on deceleration. Check bushings and the adjustment by putting a proper drill bit throug the neutral hole in the shifter and check your adjustments. If it’s a Hurst shifter, also be sure the detent limiter bolt is not too tight since limits how far the lever pushes the fork. LT1Vette, I disagree on sending it back to the builder. We don’t even know if this is a recent problem or it has been happening all along. Why do you say with certainty that it is an internal issue? After 10k miles, lots can happen. If this has been happening for 10k miles, then lots of damage could have happened simply from having things out of adjustment this long. If it is a recent issue, it could be very simple. Calling the builder to troubleshoot may be an option though. Jason Last edited by SuperNovaSS; 08-06-2023 at 05:55 PM. |
The Following 4 Users Say Thank You to SuperNovaSS For This Useful Post: | ||
![]() Quote:
I've noticed it the last couple of times I've drove the car over the past year or so and it's progressively gotten worse. I'm lucky to get a chance to drive it every 3 months due to my current schedule. My drive on Saturday wasn't really enjoyable because it continued to pop out of gear, much worse than before. I have had to send the trans back to the builder once before, but that was due to an internal failure of 3rd gear. Several teeth broke off of it during a spirited drive,(no missed gears or powershifting) and was told it was replaced with a new one. This was around 7 years ago and has only had about 3-4 K miles put on it since then. When I first put the trans in it, if I recall correctly, I used metal bushings on the linkage, something similar to this. https://www.speedwaymotors.com/Speed...et,408860.html The shifter (Hurst competition plus) was new, as was the linkage and shift levers. I did the adjustment on the shifter with the trans out of the car prior to first putting it in so that I could easily see everything. I'll go through and check the condition of the bushings, the linkage adjustment, stop adjustment and shift levers first before I pull the trans to check the internals. Thanks for the feedback.
![]() Quote:
I think you answered the question. The OP did not gives all the info at first to help us with the diagnosis. I thought it was a recent build within the year, he was driving the car quite regular and this problem had just popped up. If I follow the story right, the tranny was built a number of years ago. I would hope that this problem has not been ongoing for that reason. I would call the builder before removal and see what he says, may be just an adjustment, jam nut has backed off causing the problem.... |
