Old 08-29-2023, 09:35 PM
Devil Devil is offline
Default ZL-1 Engine Block Uncovered
So I was at my friends place checking out his collection of rusty Chevrolet Performance cars, when he asked if I had ever seen his aluminum big block. I mentioned I had not, so it rolled it out from the corner. It is definitely cool, so I took some pictures of it and documented the numbers. Checking the numbers out today, it comes out as a 1969 ZL-1 engine Winters block. That was unexpected to say the least.
www.carsinbarns.blogspot.com
The Following 4 Users Say Thank You to Devil For This Useful Post:
Damien (09-01-2023), dykstra (08-30-2023), FTC (09-19-2023), markinnaples (08-30-2023)
Attachments - The Supercar Registry ZL-1 crack.PNG ZL-1 blocks.jpg IMG_3176.jpeg IMG_0265.jpeg
Old 08-29-2023, 09:48 PM
Painted blue to try and disguise as a Ford engine?
Did it have a production date and application code stamped on the passenger side front pad?
Bill Pritchard
Old 08-29-2023, 10:52 PM
1971ls6's Avatar
1971ls6 1971ls6 is offline
If the stamp is is one of the missing 69 engines, now you are talkin big money.
Is it for sale?
Old 08-30-2023, 12:32 AM
William William is offline
Based on the casting date location, that's one of the blocks re-issued in the late '80s.
Missing sleeves.
The Following 4 Users Say Thank You to William For This Useful Post:
69 Post Sedan (08-31-2023), Carleen (08-30-2023), dykstra (08-30-2023), John Brown (08-30-2023)
Old 08-30-2023, 01:25 AM
thehornworks thehornworks is offline
Wasn't the block under cut at the top for the sleeves to recess down.
The Following User Says Thank You to thehornworks For This Useful Post:
Old 08-30-2023, 11:41 AM
EZ Nova EZ Nova is offline
YES, either counterbored for sleeve, or has a darker "sleeve" installed. I wonder if this is a "can-am" block with the treated cylinder wall to run with just the alum as a "sleeve".
My 1969 "052" ZL-1 block was painted orange when I got it as it was used in a dirt modified as a "cheater". It came out of northern Ohio around 2010.
'78 Z28 4sp being restored
'70 W30 convert TRIBUTE
'66 CANADIAN Nova SS Race Car
'69 FIREBIRD Tubbed Racecar
Old 08-30-2023, 11:57 AM
You can see the step at the bottom of the bores for the sleeves to sit on. I don't believe there is enough material between the cylinders to run it as it is.
The Following 2 Users Say Thank You to big gear head For This Useful Post:
69M22Z (08-31-2023), John Brown (08-30-2023)
Old 08-30-2023, 01:22 PM
John Brown's Avatar
Cylinder wall is almost thin enough to read through it.
John Brown
Old 08-30-2023, 07:53 PM
That's gotta be one of the 4.440 bored blocks
Old 08-30-2023, 12:36 PM
Carleen's Avatar
Carleen Carleen is offline
The only sleeves I have found that fit the 430 Can Am Block are the Darton sleeves 32160111.
And I have been waiting for them for over 2 years
