Old 10-07-2023, 10:17 PM
Default 69 Chevelle Hood
Hi Guys, the hood on my car does not fit right on the driver side rear. It sits up too high, the passenger side is fine. I have tried to pivot the driver side hinge, shimmed it which helped but seems as if I need to start all over and carefully install the hood. The car has OEM fenders on it and OEM header panel. Any process help is appreciated.
65 Corvette Coupe L78
69 L71 Roadster Survivor
69 Z/28 RS (Sold)
69 Dodge Charger R/T
70 W30 442 Auto Air Survivor
2016 Z06 Coupe M7
70 AAR Cuda (Sold)
69 L78 Chevelle (Sold)
Attachments - The Supercar Registry IMG_1707.jpg IMG_1705.jpg IMG_1704.jpeg IMG_1703.jpeg
Old 10-07-2023, 11:14 PM
How about elongating the mounting holes on the hinge so it will sit lower?
Can you provide a photo of the hinge in question?
luzl78 (10-08-2023)
Old 10-08-2023, 01:42 AM
How tight are the hinges ? worn hinges will cause that too. They can be rebuilt by Willie Wilson.
https://www.hoodhingerepair.com/
Lee Stewart (10-08-2023)
Old 10-10-2023, 03:00 AM
Pictures of hinges.
69 Z/28 RS (Sold)
2016 Z06 Coupe M7
70 AAR Cuda (Sold)
Old 10-10-2023, 01:48 PM
Strange looking rivets, not original. Aftermarket ? Left forward arm is binding badly too.
Old 10-10-2023, 07:44 PM
Woj's Avatar
Woj Woj is offline
Not sure if you did this, but if you raise the hinge on the front bolt of the hinge, it will drive the back of the hood down. I've done this numerous times. Just barely loosen the back hinge/fender bolt, position yourself with shoulders ready to push up on the hood just forward of the hinge; then loosen the forward hinge bolt until you can raise front of the hinge. Just do an 1/8' or so at a time.
Worn hinges can be a problem too. Good luck.
Old 10-10-2023, 08:09 PM
Donnie's Avatar
Donnie Donnie is offline
looks like a reproduction cowl to hood seal that can be an issue too.
69 SS L78 Chevelle
70 SS 396 Chevelle
Old 10-11-2023, 02:26 AM
Regarding the hood hinges, they were on the car and looked aged so thought they were original.
I have tried to pivot hinge no luck.
Yes aftermarket cowl seal and have been looking for an NOS haven’t found one yet. I may remove part of the cowl seal to see if that helps. I have stuck my hand under the hood at the problem area but seems the cowl seal does not have a lot of pressure from the hood
69 Z/28 RS (Sold)
2016 Z06 Coupe M7
70 AAR Cuda (Sold)
Old 10-12-2023, 01:18 PM
Woj's Avatar
Woj Woj is offline
NOS cowl seals are difficult to find. I've seen guys literally cut them down by half and that has helped. You can remove it all together and see if that is a factor.
Old 10-14-2023, 01:41 AM
Yea my next move is to remove it and see if that helps. Wish I would had saved the original one. It was battered but better than this crap.
69 Z/28 RS (Sold)
2016 Z06 Coupe M7
70 AAR Cuda (Sold)
