Old 02-17-2024, 09:06 PM
LetsFNgo's Avatar
LetsFNgo LetsFNgo is offline
Default MRT CD Ignition
Hello everyone. New member first post. Though I spend a lot of time over the the amc forum. I have a question about an ignition system I was offered to buy. Due to the included paperwork I believe the gentleman’s story 100%, but am unable to find absolutely any info online about this ignition system.
It was removed from a factory backed Pro Stock AMC Gremlin sometime in the 70’s, and was on the car in the 1970-73 timeframe. If I can figure out to how post some pictures I’ll add them. However the distributor is a GM transistorized top mated to an AMC bottom with a Delco Remy Transistor ignition box. That box is then connected to a large box with a sticker that says “MRT Ignitions Capacitor Discharge Ignitions. 7309 Jamieson Ave Reseda Calif 91335”
Paperwork has it being delivered to Dennis Peck from a Mike Dombrowski and some talk about the spark plug gap. Has anyone heard of this ignition system before or have any paperwork on it?
The Following User Says Thank You to LetsFNgo For This Useful Post:
big gear head (02-18-2024)
Attachments - The Supercar Registry IMG_2898.jpg IMG_2821.jpg IMG_2810.jpg IMG_2809.jpg
Old 02-18-2024, 01:15 AM
LT1vette LT1vette is offline
If the original (GM) harness wiring has been cut/spliced it is scrap....Missing the correct male/female connections.....
Old 02-18-2024, 10:59 AM
LetsFNgo's Avatar
Scrap as in would cause electrical interference? Or scrap because a restorer couldn’t use it? If you say the car it would all be going into a couple of spliced wires isn’t going to change much.
Old 02-18-2024, 11:39 PM
The wiring harness has a built in resistance that is needed to make the whole system work. Any change will affect the performance, even making it possible to not work. The harness is extremely long (Corvette is) and it all has to be bundled under the fender. Tends to look messy and guys have trimmed it have better eye appeal...
