Old 02-16-2004, 08:08 PM
berger berger is offline
Default early 69 no x codes
could anyone help me with a 69 camaro early vin with no xcodes but complete except motor, can give vin and descriptions of components, thanks matt
67 Rs modified stormer z28 482cu in.yenko camaro
67 327 camaro
69 SS 396 camaro
Old 02-16-2004, 08:35 PM
Default Re: early 69 no x codes
5 leaf multis orig, 12 bolt, 4spd, daytona yellow, black interior, plain jane, no console, no trim, 6000 yellow line /7000 red line tach orig, car has spoiler with springs that take your head off when you open trunk, disk brake front end, 555xxx vin, about a half hour away from scuncio dealer...
67 327 camaro
69 SS 396 camaro
Old 02-16-2004, 09:05 PM
Jeff H Jeff H is offline
How many fuel lines running from the tank up to the engine? Small block or big block heater core? Dual exhaust plate on the driver's side rear frame rail?
Old 02-16-2004, 09:28 PM
exhaust plate is there, heater delete!! I didn't check the fuel lines, ahd a bitc# of a time climbing under it w/ 4 flats, cars' interior is orig done to rug
67 327 camaro
69 SS 396 camaro
Old 02-16-2004, 09:34 PM
bkhpah bkhpah is offline
Has to be Canadian for factory heater delete in 1969 not lower 48...BKH
Old 02-16-2004, 09:44 PM
well we're in ma so we're close, guy did say he bought it in new hampshire, after we asked where he got it, about 20 yrS AGO, never got around to restoring it.
67 327 camaro
69 SS 396 camaro
Old 02-16-2004, 10:28 PM
Sounds like you should run the vin past GM of Canada, and if Brian is correct, they should be able to document it.
Peter
Old 02-18-2004, 05:45 AM
Kurt S Kurt S is offline
???? Never made such an animal in 69.
Kurt S - CRG
