Old 05-15-2004, 08:06 AM
68TopStock 68TopStock is offline
Default Removing Chrome Plating
What is the most effective non-destructive way to remove chrome plating? Has anyone had any first hand experience recently?
Old 05-15-2004, 09:45 AM
68z302 68z302 is offline
Default Re: Removing Chrome Plating
I'm pretty sure this can only be done as a reverse process of chroming.
It's not a do it yourself deal without the right equipment.
A chrome shops your best bet.
Rob
'68Z, original drive train
AS1 AO1 D55 J52 U17 U69 Z28
Old 05-15-2004, 05:30 PM
resto4u resto4u is offline
Ken, i think this can be done with a lite acid solution bought at a hardware store. I think i rememeber dennis gilbert did something like this, send him a email. Not sure what kind of acid it was. Roger
67 Z28, 67 RS/SS 396 Canadian, 73 Camaro Z28/LT Carolina Blue
Old 05-15-2004, 07:51 PM
Roger,
If tht's the case could you PM me with that too?
I didn't think you could do it at home.
The only acid you can get in a hardware, as far as I know, is muratic acid used for etching concrete.
Muratic acid is also unbelievable for removing rust from steel!
Rob
Old 05-15-2004, 08:54 PM
Denis Denis is offline
I use a solution of 3 parts distilled water to 1 part muriatic acid. Takes about 10-15 minutes to take the chrome off. Solution is neutralized with baking soda afterwards.
Make sure you work in a well-ventilated area.
Old 05-15-2004, 08:58 PM
I've done this to Exhaust tips,and it works very well.
Don't ignore Denis's Ventilation & baking soda comment.
Old 05-17-2004, 07:57 AM
Denis and others,
Thanks for the info.
