Old 01-27-2005, 12:19 AM
454nut 454nut is offline
Default Chevelle Firewalls
Are the separate firewalls for AC vs nonAC cars?
I have a 1969 AC Chevelle, but I am thinking about removing the AC.
Thanks,
Matt
Old 01-27-2005, 01:24 AM
Alss's Avatar
Alss Alss is offline
Default Re: Chevelle Firewalls
Yes...openings for the heater and A/c are different than just heater.
ALbert
1969 Beaumont 540 th400 3.70
1968 Camaro ragtop LSA ZL1
Old 01-27-2005, 04:30 AM
Thanks. Is there a good way to only have the heater box and look like it is supposed to be that way?
Old 01-27-2005, 09:18 AM
Zman Zman is offline
You have 2 options...
There is an aftermarket "A/C Delete" heater box available.
I see them all the time on Evilbay. They don't look correct, but it does eliminate the A/C stuff, and covers the Big hole from the A/C heater core.
The other option, is to fab up a piece for the firewall, and cut the opening the correct size, and use the standard heater core, and box. That's what I did on my Nova, and it looks factory.
Dennis
69 Nova 355, M-21, 3.90 12 bolt
68 Chevelle SS 396 4 sp
Old 01-27-2005, 11:19 PM
Dennis,
I like your idea about fabing a cover. Would you please post a pic of it? I think it would really help me.
Thanks,
Matt
Old 01-28-2005, 11:07 AM
Matt,
Sorry, I don't have any photos..at least nothing you could get any info from.
I just took a piece of sheet metal, and made a piece from the top "seam" of the firewall at the cowl, to just past where the heater hoses exit the firewall. I had the donor car available, so I knew where, and how big to make the hole for the heater core. Just weld in the piece, grind down the welds, and paint. The heater core cover will "Hide" most of it anyway. A little seam sealer at the original seam, and you're all set.
It really wasn't a big deal.
Dennis
