I went through the drivethru at McDonalds a little while ago and rubbed up against a damn bollard!!! Well now I have red bollard paint all around my wheel well... How can I get this off without ruining my paint and having to have the area repainted??? I'm not having a good day.....
https://t.me/pump_upp |
Did you get Fries with that?
Try wet sanding & rubbing compound. |
wet sanding the area with a hi-grit paper should do the trick.
then hit it with a buffer, mild pad and compound... then swirl mark reducer.
Follow me on Instagram: https://www.instagram.com/mbcgarage/ |
what grit paper? and what kind of rubbing compound should I use? I don't know jack when it comes to paint and finishes... Thats why my Nova and Olds look the way they do.. lol. I have all the tools..just haven't attempted it yet...
1200-2000. make sure you get WET sand paper. It should have a grey backing NOT a tan backing. Move in "X" directions. The human eye cannot pick up defects in paint that criss-cross. Do not role the edge of your fender with the sand paper, otherwise you're going to remove paint. Also, make sure you get a wet sanding sponge and DO NOT use your finger tips to wet sand.
3M makes a great compound and its pretty moderately priced. They also make a swirl mark remover. When you're all done sanding and buffing, get some Zaino car polish, clay bar and wax the area you wet sanded. -Dan
Dan. thanks a lot
