Old 03-17-2008, 05:10 AM
JK98SS JK98SS is offline
Default 70 Firebird project, decode the vin and trim tag ?
I have a prospect on a 1970 Firebird. I am waiting for the trim tag info. He is a Ford guy and picked this up, but wants to play with ponies instead.
Old 03-17-2008, 05:13 AM
Default Re: 70 Firebird project, decode the vin and trim t
VIN I got from him.... 223870n114248
Old 03-17-2008, 05:49 AM
HEMIBEE HEMIBEE is offline
fax that vin to PHS and for 55.00 you will have all the info you need. with the Pontiac's it is one heck of a great tool to have. for 10.00 extra they will fax you back the info within 1 hour.
Rich Straub
raiv 69 judge, ra3 70 judge, 71 judge,74 SD trans am,71 cudas, 67 189 Corvette roadster, Quicksilver 68 HURST
z-10 396 camaro, 69 HEMIBEE
Old 03-17-2008, 06:00 AM
ddmrk ddmrk is offline
Its a base Firebird, wrong rad support for a 70
Old 03-17-2008, 09:01 AM
you mean the whole core support is wrong for the car? It is obviously an a/c car. I just figure if it came with a 12 bolt and still has it, the car is worth what he wants for it in just parts.
I don't wanna spend $55 on a car that I may not even get.
Old 03-17-2008, 09:45 AM
Fast67VelleN2O's Avatar
What do you think a restoration will cost? More than $55. Spend the 2 bucks now to find out what you are buying.
Day 2 is Life.
Old 03-17-2008, 09:49 AM
My point is, I just wanted some general info without doing the PHS. I used PHS on my 69 GTO, not doubt a great service. But I am not going to dump the money on every pontiac prospect.
Old 03-17-2008, 05:19 PM
StealthBird StealthBird is offline
By the VIN # you posted, it's a base Firebird. The BOP 12-bolt was only available in the 70 Trans Am, and it's quite rare. Did the guy say it had a 12-bolt?
1959-1980 Pontiac Window Sticker Reproductions : PontiacWindowStickers.com
DVD's for Musclecar fans! MusclecarFilms.com
Old 03-17-2008, 07:11 PM
68 Vert 68 Vert is offline
Formula's also received the 12 bolt rear.
Mike
Old 03-18-2008, 06:07 AM
yes the hole support has been replaced sometime in its life if you look at the top of the rad support it has 2 dipresion one on each side it should not have them all 70/72 had a flat top panel here is a picture of a correct one
