Old 06-12-2008, 10:39 PM
*hotrods* *hotrods* is offline
Default Could this be a COPO ????
The vin is 124379N614741 car is X44 paint code 72 (Hugger Orange)Car has factory 12 bolt, M21 dated late jan. 69 appears to be factory big block with correct mounts and heater core box.
Old 06-12-2008, 10:42 PM
Hylton Hylton is offline
Default Re: Could this be a COPO ????
Check the stamped code on the rear end. Should be "BE". Also, any sign of a cowl hood?
It is impossible to certify a COPO or Z/28 as authentic without verifying that it is not a rebody...
Old 06-12-2008, 10:45 PM
Stefano Stefano is offline
That would be very early for a COPO Camaro, Non ZL1, Non Yenko Car?
Old 06-13-2008, 12:11 AM
I know of a 618xxx COPO 03d car
Jake is my grandson!!
Old 06-13-2008, 12:35 AM
It appears that the car has had lots of mods on and off over the years. The build date is 03A, I just thought that it could possibly be a COPO due to the X44 code 72 and 12 bolt. Is there a vin listing of all the COPO's made??
Old 06-13-2008, 04:01 PM
No, not really. There is a list of known COPO cars but there are still a few that are unknown. You need to scrutinize the car. You also need to try and find out the history of the car. Like I said, check the code on the rear. Check for evidence of the car being a factory cowl hood car.
Old 06-14-2008, 06:45 PM
William William is offline
A few?
Do the math - the production totals for L72 Camaro engines at Tonawanda have been known for years. 822 MN and 193 MO; 1,015 total. With an installation rate of maybe 95% that's 965 COPO Camaros. Less the 200 or so Yenkos leaves 765 COPOs sold through other dealers. The existing knowledge base covers half or less of the total.
There's a lot left to learn and a lot of unknown COPOs.
Old 06-14-2008, 07:15 AM
supercomp 8.90 supercomp 8.90 is offline
i have in my notes two berger cars in the 608xxx range one a double copo, pm me the body # and i will check it out for you.
Old 06-15-2008, 05:10 PM
I'm assuming that you are referring to the trim tag sequnce number???
