Old 02-08-2009, 06:22 PM
1randy 1randy is offline
Default Re: really cool 70 Z28..simply the best.
i dont think i would try to start it, it would wipe the cam out almost imediatly, maybe prime the oil pump but still risky.
Old 02-08-2009, 10:22 PM
Charley
I see you posted a pic of the one rear spiral shock.
Can you catch the other rear part number,sticker & date as well?
And if at all possible,can you relay the Front spiral shock numbers,broadcast stickers and dates from both sides too?..Pics aren't really necessary,but appreciated as I know how difficult it can be to get in these areas,especially the fronts.
I'm curious to see how close all four of these actually do match up.
Thank You..
Old 02-09-2009, 02:39 AM
GaryH GaryH is offline
Left rear off for the first time. arrgh..
I don't see any drum retaining spring type clips. Were they not in use at that time? I used to rip them off with side cutters and toss them. Great pics Charlie! Keep them coming.
Gary
71 LT-1 Vette
85 IROC (Modified)
09 SRT8 Challenger 6sp Kenne Bell on the way
Old 02-09-2009, 02:43 AM
No it had no clips. Had a cobweb that I thought was a clip though. It will be a bit before I get near the other shocks.
Old 02-09-2009, 04:58 AM
clip on pass side head to hold temp sending unit wire.
Old 02-09-2009, 04:59 AM
cloth tape on wire
Old 02-09-2009, 05:02 AM
same wire goes up and loops over the TCS wire harness. If I were putting this car back together I would not have looped it over. Might mean nothing but just the kind of crap I like. Also notice the pink lettering on the trans.
Old 02-09-2009, 05:05 AM
nut that holds TCS solenoid looks like it was never tightened.
Old 02-09-2009, 05:06 AM
Notice how different the plating color is between the bracket and the booster
Old 02-09-2009, 05:07 AM
also on this bracket...also notice there is "NO" pipe dope or teflon tape on any of the fittings.
