Old 01-27-2009, 02:46 AM
Camaroresto Camaroresto is offline
Default My roller moto 302 in my z28 did a freaky thing...
If anyone has ever had this happen and knows why I would like to know. The car had been sitting. Dead battery. Charged battery. Pumped gas. Wouldn't fire. Let it sit. Turned it over it fired and the whole engine shuttered, carb fire and blew the timing cover seal, front oil pan seal and for some reason tried to push the mech. fuel pump off and cracked it. Crank case explosion? Motor has been fine running condition for over 10 years. I don't get it. Any thoughts?
Bryan Paschal
1969 Cortez Silver Z/28
1969 Cortez Silver SS396 convertible
1971 Copper RS Z/28
Old 01-27-2009, 03:04 AM
TDW TDW is offline
Default Re: My roller moto 302 in my z28 did a freaky thing...
Raw fuel in the crankcase. When you pumped it trying to start it, there was way too much fuel dumped down the intake. It has to go somewhere, and the only place is down into the oil pan.
Tony
55 Nomad Gasser
70 SS 427 Nova
34 Ford Sedan..Hemi powered
Michigan/ Florida
Old 01-27-2009, 05:51 AM
beater68427 beater68427 is offline
Ditto!! Some reason you got alot of fuel in the crank case and well it flashed... I can not see you pumping it that much, but possible, I would also (when you get it fixed) check the carb needle and seat etc make sure it was not running fuel out. Also was the car running rich before you parked it, fuel will mix and stay with the oil for some time. A real bummer I feel for you a simple problem turned bad!! But on the better side of things the car didnt burn down...
Old 01-27-2009, 02:01 PM
TDW TDW is offline
Also you should check the floats and the float levels. If the floats have a pin hole in them, they will not shut the fuel flow off and it will seep. If the level is too high, it will flood it. Like said above, it could have been much worse!
Tony
55 Nomad Gasser
70 SS 427 Nova
Michigan/ Florida
Old 01-27-2009, 07:39 PM
Check your fuel pump. I wouldn't have thought that much fuel would go pass the rings.??
Jake is my grandson!!
Old 01-27-2009, 08:10 PM
It can if it's in liquid form and an abundance of it too.
I can relate and hope to never revisit that again..
