Old 12-31-2009, 04:25 AM
The Boss's Avatar
The Boss The Boss is offline
Default What to look for when looking at a COPO???
Might be checking out a 69 Camaro that the seller claims is a 9561 COPO. I'm a Pontiac guy and know everything to look at on a GTO or a bird, but am lost when it comes to this car. I know about the hidden vin under the cowl cover, but what other codes should I look for, and where would they be?
Also what would the value of a nice clean driver be?
Some guys they just give up living
And start dying little by little, piece by piece,
Some guys come home from work and wash up,
And go racin' in the street.
Bruce Springsteen - Racing In The Street - 1978
Old 12-31-2009, 02:21 PM
parkbrau's Avatar
parkbrau parkbrau is offline
Default Re: What to look for when looking at a COPO???
I would look for documentation. X-11 or X-44 code on the trim tag would be a plus. Do you have the VIN and Trim Tag info? Pics of those will assist the folks in the know. I'm not sure what the value is.
Old 12-31-2009, 05:16 PM
The Boss's Avatar
I'll get them, thanks.
Old 12-31-2009, 07:10 PM
Others here can give better advise than I but if you're on your way now before others get a chance to chime in, here's a few things..
Is it supposed to be a complete original car or a supposed 9561 car w/ parts missing/removed?.
Besides obvious Vin and Cowl tag codes, things to look for and make sure to take pics of to compare w/ other known genuine cars are the pierced hole in the cowl also make sure to get ALL Cowl tag #'s as the body #'s were sometimes consecutive also if D80 is noted check against build date..
If supposed original parts note and take pics of all engine and trans codes and stampings also check for the original BE rear axle code and if it's there get a pic or or at least pencil rubbing you can compare w/ other known genuine stampings also check fenders and tailpan for signs of emblems?.
Also try Googling the Vin as many of us here have tried to leave trails to real, fake or suspect cars on past threads here and elsewhere you may find online..
Best of luck and Happy New year!.
Old 12-31-2009, 07:48 PM
William William is offline
If the OE VIN-stamped MN or MO engine is gone and there is no factory paperwork there isn't anything left to rule it in as a COPO. Most of the required and standard COPO equipment was also present on an L78 Camaro SS. Here is some stuff to look for:
VIN: should be an 8 cylinder [124379] Norwood build no earlier than about N578xxx. Even that is a stretch; virtually all earlier COPOs were Yenkos.
Chassis: Should have power front discs [racers took 'em out], COPO-specific 12 bolt posi BE code axle. Lots of COPOs ended up with a 9-inch or a DANA 60. I have had 2 BE axles and known of several more. They aren't that tough to "create" so that is no longer an absolute indicator. All had dual exhausts and should have the hanger plate tack-welded to the LH rear frame rail.
Body: All had the ducted hood with factory wiring and holes. Optional on SS after 1/1/69. 4-speed must have Muncie-specific speedo cable routing.
Cooling: HD radiator with 90º upper hose connection. BB specific heater.
Body tag: Most are X44, some X11. A very few early Yenkos were X66 or X22. Cannot be X33, X55, X77. Some COPOs were ordered in groups and had consecutive 'NOR' numbers on the tag. Some of the groupings are known. But that does not apply to all of them by any means [not even the 50 Gibb ZL-1s] so if is not part of a group it doesn't rule it out.
Get data, pics, post here!
Old 12-31-2009, 08:05 PM
To add to the above post, it would appear that some BL code rearends have been turned into valuable BE units by entrprising people. I'd be looking for an unrestored original car and having it done. The chances of getting a legitimate restored car are getting more remote every day. You need ALL the documentation and still have someone with knowledge to check out the car itself. Even experts get fooled so go slowly.
Old 12-31-2009, 10:53 PM
Unreal Unreal is offline
Virtually all the COPO "indicators" can be added to any car. As William stated, the COPO and the L78 shared most of the HiPo stuff, so if the original engine is gone, it's hard to prove. If the car is unrestored, and has the "indicators" and the original cowl tag (a lot of if's) AND has X22 or X66, it would most likely NOT be a COPO. So if it has all the indicators, and X11 or more likely X44 on the tag, I'd be getting excited. I think one X22 COPO has been found, and no X66 non-Yenko COPOs found.
Old 12-31-2009, 11:50 PM
elonblock elonblock is offline
Piggybacking on what others have said, here are some other clues you can look for:
Big block heater box cover
If the car has a tach, is it a big block tach?
Cowl induction throttle arm
Single fuel line
Big block springs in the front and rear.
Big block engine mounts
No badging holes on front fenders
Standard grill
As many have already said, there can be a lot of the COPO stuff added to a car, but not everybody does a thorough job of adding "everything". For example a friend had looked at a car advertised as a COPO. It had all the COPO indicators except someone had drilled the hole for the cowl induction wiring in a different location from the normal factory hole.
The car looked really nice, but the incorrect hole told the whole story of a clone.
And have another pair of eyeballs look at the car also. If you are fairly certain it is a COPO car then it is well worth the money to have it documented or authenticated by someone who offers these services.
Elon
69 COPO Camaro
