Old 02-07-2010, 11:47 PM
enio45 enio45 is offline
Default Trans speedo adapter for 69 yenko camaro
Need one.
I believe they were made by SW for the 69 yenko camaro's.
Looking for 1 please.
Eddie M
Camaro-less
87 El Camino SS
Few Ferrari's
Old 02-08-2010, 06:14 AM
Lynn Lynn is online now
Default Re: Trans speedo adapter for 69 yenko camaro
While many 69 Yenko's may have had the adapter, I believe it is common on any car shipped with a Muncie and a 4:10 rear. They show up on epay from time to time.
Old 02-08-2010, 06:28 AM
al8apex al8apex is offline
they also have a multitude of ratios ...
Jim R
Scottsdale, AZ
Old 02-08-2010, 06:49 AM
Question, so my 69 Z with a BV rear (4:10 ratio) would have this adapter as well?
I dont recall seeing it - i thought they changed the internal plastic gear for the correct speedo reading?
Eddie M
Camaro-less
87 El Camino SS
Few Ferrari's
Old 02-08-2010, 07:37 AM
John Brown's Avatar
I recall Ed Cuneen having those reducers listed in his copo book along with part numbers and ratios.
I loaned my book out and it never came back.
John Brown
Old 02-08-2010, 07:43 AM
Not necessarily. You would think that it would be uniform across the board. Can't remember the criteria for when a car got the adapter.
Old 02-08-2010, 06:49 PM
resto4u resto4u is offline
you can buy them from speedometer repair guys. Bob's speedometer repair has a website. Roger
67 Z28, 67 RS/SS 396 Canadian, 73 Camaro Z28/LT Carolina Blue
Old 02-08-2010, 07:03 PM
Here is a source:
http://www.transmissioncenter.net/sp...atio%20adapter
the original stuff, sorry about the large pics:
or
as I stated above, they come in a LOT of different ratios ... good luck
Jim R
Scottsdale, AZ
Old 02-08-2010, 08:22 PM
Jim, excellent info - thank you for posting this.
Ill give them a call to see what they have avail.
Im still confused what triggers the use of them , especially if the 69Z's had 4:10 gears and M21 and no adapter used, vs the yenko cars had them and they run the same gears, tires and trans.
Maybe it was used if they went to TT wheels vs the standard YH wheels? Not sure if there was any diff - should not be thought???
Eddie M
Camaro-less
87 El Camino SS
Few Ferrari's
Old 02-09-2010, 07:06 AM
acelr8 acelr8 is offline
I believe the adapter to be a 90 degree not a straight through style as shown.The part number is 6476736 and heres to hoping you find two,as I need one as well.Jeff
