Nice work "Mac". Now, can you make your own sender with some string, a paper clip, and a wad of chewing gum? [img]<<GRAEMLIN_URL>>/dunno.gif[/img] [img]<<GRAEMLIN_URL>>/beers.gif[/img]
Sam... ![]() |
<div class="ubbcode-block"><div class="ubbcode-header">Originally Posted By: Ls6racer</div><div class="ubbcode-body">found this info online.
http://www.lbfun.com/warehouse/tech_info...geCF-Thread.pdf </div></div> Wow! Those guys make me look like like an amatuer. (Hey wait aminute, I am) [img]<<GRAEMLIN_URL>>/grin.gif[/img] One thing I notice is that their chart readings go the opposite way mine do ohm-wise - their resistance drops as temp rises. I'll recheck and see if I'm reading my gauge wrong - or just putting decimal points in wrong places. |
OK, I kicked the wife out of the kitchen and did a little experimentation on the stove with a pot of water, a candy thermometer and a digital ohmmeter. Here are the results:
80 degrees: Wells at 650 ohms, LL at 573 ohms 90 degrees: Wells at 526 ohms, LL at 445 ohms 100 degrees: Wells at 429 ohms, LL at 365 ohms 110 degrees: Wells at 328 ohms, LL at 266 ohms 120 degrees: Wells at 283 ohms, LL at 227 ohms 130 degrees: Wells at 250 ohms, LL at 200 ohms 140 degrees: Wells at 216 ohms, LL at 170 ohms 150 degrees: Wells at 198 ohms, LL at 155 ohms 160 degrees: Wells at 173 ohms, LL at 133 ohms 170 degrees: Wells at 157 ohms, LL at 119 ohms 180 degrees: Wells at 135 ohms, LL at 101 ohms 190 degrees: Wells at 120 ohms, LL at 89 ohms 200 degrees: Wells at 109 ohms, LL at 79 ohms 212 degrees: Wells at 104 ohms, LL at 75 ohms And as a result of my weekend TempSender-Palooza, I am going with the Wells sender as the one that makes my temp gauge far more accurate when it comes to reading what the coolant temperature actually is, as corroborated by an actual thermometer as well as a mechanical temp gauge. (That is, until the original GM unit arrives) I will update with the original GM sender when I get that. The original ones have the part number stamped above the threads. The later GM ones have no part numbers whatsoever and seem to be a generic replacement. |
Just took the car out for a test drive. I hooked up the mechanical gauge in the sender location. It's about 97 degrees outside at the moment and the car ran around 190 degrees most of the trip with the A/C on full blast.
Once you sit and idle for an extended period or shut the car down, the temp really spikes (230) but I think that is due more to the sender location on Pontiacs that is right between the two exhaust port tunnels on the HO cylinder heads. So actually, the heat soak from the exhaust manifolds may play a major part in some of the high readings when there is no airflow. The heat soak may be heating the outside of the temp sender more than the coolant is heating the sender bulb inside the cyl head. |
OK, just got an original, vintage GM 1513321 temp sender, here is the updated chart:
80 degrees: Wells at 650 ohms, LL at 573 ohms, GM at 549 90 degrees: Wells at 526 ohms, LL at 445 ohms, GM at 524 100 degrees: Wells at 429 ohms, LL at 365 ohms, GM at 409 110 degrees: Wells at 328 ohms, LL at 266 ohms, GM at 365 120 degrees: Wells at 283 ohms, LL at 227 ohms, GM at 323 130 degrees: Wells at 250 ohms, LL at 200 ohms, GM at 272 140 degrees: Wells at 216 ohms, LL at 170 ohms, GM at 227 150 degrees: Wells at 198 ohms, LL at 155 ohms, GM at 195 160 degrees: Wells at 173 ohms, LL at 133 ohms, GM at 175 170 degrees: Wells at 157 ohms, LL at 119 ohms, GM at 157 180 degrees: Wells at 135 ohms, LL at 101 ohms, GM at 140 190 degrees: Wells at 120 ohms, LL at 89 ohms, GM at 125 200 degrees: Wells at 109 ohms, LL at 79 ohms, GM at 109 212 degrees: Wells at 104 ohms, LL at 75 ohms, GM at 102 Looks like the Wells sender is pretty darn close to the original GM sender's specs. I'd say it's a dead-on match given my pot of hot water on the stove, scientific method. |
Thread Tools | |
Display Modes | |
