Old 02-23-2012, 12:58 AM
Fast67VelleN2O's Avatar
Default Re: 63 Corvette SWC L84 Restoration
That transmission has the wrong input bearing retainer for a 1963. If you're using the 3788421 bell housing... that takes the small bearing retainer. For Corvettes, the early assembly line correct piece is aluminum. Later service replacements were cast iron.
-Matt
Day 2 is Life.
Old 02-25-2012, 02:57 PM
napa68 napa68 is offline
<div class="ubbcode-block"><div class="ubbcode-header">Originally Posted By: Fast67VelleN2O</div><div class="ubbcode-body">That transmission has the wrong input bearing retainer for a 1963. If you're using the 3788421 bell housing... that takes the small bearing retainer. For Corvettes, the early assembly line correct piece is aluminum. Later service replacements were cast iron.
-Matt </div></div>
You're right! I missed that. Thanks Matt.
Old 04-08-2012, 03:39 PM
time this weekend (and a little ambition) to tear into the 63. I snapped some pics along the way.
junk exhaust
ned to send the manifolds out to have the flanges repaired. I suppose Jerry McNeisch is the best choice
Data tag on the F.I unit
Intake casting and dates
Old 04-08-2012, 03:48 PM
This car has the original radiator support. It's rusted more than I originally thought. I'll just have to be on the lookout for a nice used one. Please contact me if you know of one.
Old 04-08-2012, 03:53 PM
GRNDNL GRNDNL is offline
Does the radaitor support bolt in?
Keith & Amanda
70 GS 455,
87 GN,
01 Firehawk,
Old 04-08-2012, 04:02 PM
And were out!
Old 04-19-2012, 12:03 AM
<div class="ubbcode-block"><div class="ubbcode-header">Originally Posted By: GRNDNL</div><div class="ubbcode-body">Does the radaitor support bolt in? </div></div>
Yup! Thankfully! [img]<<GRAEMLIN_URL>>/smile.gif[/img]
A little progress this week.
My 609 pump
stripping the oil pan
and my buddy Kevin checking the cam install
Old 04-19-2012, 12:13 AM
Then the bad news................I do believe.
Is this from a rocker stud that is not installed straight?
It can't be normal............can it? I've never seen it.
Old 04-19-2012, 07:59 PM
Stop by with the radiator support, doesn't look that hard to fix from the pics.
My green plow truck had the same thing with the rockers, some of the guide plates were wrong, still ran it for years like that.
Keith & Amanda
70 GS 455,
87 GN,
01 Firehawk,
