Old 08-03-2012, 12:19 AM
Nova_Guy Nova_Guy is offline
Default Re: Day 2 parts discussion
<div class="ubbcode-block"><div class="ubbcode-header">Originally Posted By: Hemicolt</div><div class="ubbcode-body">I was always under the impression that the color differences were to indicate the gph rates. Red being the low end,
blue in the middle and the black pump being the highest rating. But that system may be something that was put into
place in the 1980's or after.
However, I would agree that the pump should be at least 1970's based on the body design and America decal. Dave will
probably educate us in a bit.
Also, what are thoughts on using an early pump with todays fuel? I was probably going to use a new
pump and paint it blue all over and apply one of the decals on the bracket. Unless of course one of the old ones will work. </div></div>
I was told years ago that the only difference between the red and blue pumps was the spring in the bypass. My car had a blue pump on it when I bought it in 1985. It went bad and I replaced it with a red pump around 1986. I swapped the spring out of the blue pump into the red pump. It worked just like the blue pump did for many years. I had to replace it in 2004 when it started leaking really bad. So I bought a new blue pump and it weighed about half as much as the old blue pump. The new pump lasted about 2 years before it started overheating and quitting. Nothing changed except the pump so it wasn't wiring or fuel line location.
Old 08-03-2012, 02:22 AM
Plowman's Avatar
Plowman Plowman is offline
Rust in and on the tank could have changed in two years. You could try to put a magnet on the tank at the lowest point,with tape,it can help{low cost try}.
Old 08-03-2012, 02:51 AM
C1SS396 C1SS396 is offline
Love this day 2 engine .. Reminds me that the day two look was and is about going faster making it your own /standing out and having fun doing it ..
I am out there finding it so you don't have to .
Old 08-03-2012, 01:54 PM
Nova Jed Nova Jed is offline
Very Patriotic! That's pretty cool!
Jed 69,70,71 Nova's 1955 Bel Air and a 69 Camaro.
Old 08-12-2012, 04:36 AM
Found these this week ..Cure Ride Drag shocks look to be PRE 68 Chevy II ..Did get chance to double check the part# yet .
Old 08-12-2012, 12:52 PM
real tough to find. A nice score!
Old 08-18-2012, 12:42 PM
Glenn70 Glenn70 is offline
Dont know if this qualifies for day2 but is relevant to way back car stuff
[/img]
[/img]
Old 09-09-2012, 02:06 AM
The Dude The Dude is offline
Old 09-09-2012, 02:41 AM
Holy crap. I just wet myself. Does this mean I have a day two &quot;problem&quot;?
Old 09-09-2012, 05:00 AM
TheNovaMan TheNovaMan is offline
Send a message via AIM to TheNovaMan
What motor does that scattershield fit?
~Pete
I know enough to know that I don't know enough.
