Old 09-05-2013, 03:46 AM
W117Monte's Avatar
W117Monte W117Monte is offline
Default Preventing surface rust in unheated garage
My garage is attached to my house, but only on one side. I noticed last year that my wheels and other parts had some light surface rust on them after winter. The garage is basically 5-10 degrees warmer than the outside and im sure just as damp. Does anyone have any tips to prevent the dampness and surface rust? possibly parking the car ontop of plywood would help?
Thanks
So when the 455 came out with the MarkIV Ram Air, A beefed lower end, And a carter high riser set up, I was online! 390 HP. 500! Foot lbs of torque. Whatever that is.
Old 09-05-2013, 07:51 AM
ZLP955's Avatar
ZLP955 ZLP955 is offline
Default Re: Preventing surface rust in unheated garage
I too have an unheated garage, and have found that the best way to limit (if not completely eliminate) conditions that favor rust is to improve airflow; I have a couple of oscillating fans hooked up to timers so they come on daily, and then open up the doors and windows whenever conditions are milder.
Tim in NSW, Australia
Old 09-05-2013, 08:02 AM
jannes_z-28's Avatar
jannes_z-28 jannes_z-28 is offline
There are humidity controls that you can activate the fans with. If you have a lot of humidity the fans will run 24/7.
Other options is a car tent with ventilation, http://www.carcapsule.com/
Jan
Jan Suhr
Stockholm, Sweden
1969 Camaro Z/28 ProTouring
My Car My Book My Photos
Old 09-05-2013, 10:59 AM
I park my car on a piece of marine carpet cut to fit the one garage bay I use. I also use Rem oil, Boeshield T-9 or WD-40 on all unpainted, natural finish parts, floors etc. on my car. I just keep spraying and wiping and that seems to help all year.
Old 09-05-2013, 11:52 AM
Hemicolt Hemicolt is offline
If you can't install a heat pump, a dehumidifier works good for pulling moisture out of the air. Gibbs Coat is a good product for protecting bare metal. It doesn't leave an oily residue.
Old 09-05-2013, 12:52 PM
Billohio Billohio is offline
I was checking out the capsule too. Might keep the cat off too! Also ran across a car bag that works on moisture
Bill
Old 09-05-2013, 12:56 PM
XXXGoldL34M20's Avatar
I have a 3 car garage with no heat in the winter, my large dehumidifier takes care of all my problems, also the large rubber floor covers I bought from the price club helps keep the humidity down. No rust [img]<<GRAEMLIN_URL>>/biggthumpup.gif[/img] It also helps that I have insulated garage doors and spray foamed walls and ceiling. If it is -20 outside it is 40 degrees in my garage and that's with no heater.
Old 09-11-2013, 01:27 AM
wheelhop wheelhop is offline
I've got a car capsule and think it is a great way to keep the air circulating and protect the car from varmints. Used it last winter in an unheated situation and it worked great.
Old 09-11-2013, 12:43 PM
WILMASBOYL78's Avatar
Important things are:
keep the air moving..
remove humidity..
good vapor barrier on the floor..
de-humidity packets inside the car along with dryer sheets..
bare metal protected with whatever product you like...
I would tell you about our car jackets...but Sammy will start in about &quot;sleeping bags&quot; so we won't go there [img]<<GRAEMLIN_URL>>/rolleyes.gif[/img]
wilma
02 Berger 380hp #95
Lots of L78 Novas
Join National Nostalgic Nova!
70 Orange Cooler
69 Camaro
Old 09-11-2013, 01:08 PM
68l30's Avatar
68l30 68l30 is offline
Carjacket.Been using it for 20+ winters......you take it out the same way it went in. I also use Plywood on the floor and have ceiling fans running in the summer to keep the air moving. I've never had an issue. Dry dry dry...
BIG
