Old 11-23-2013, 01:29 AM
kwhizz kwhizz is offline
Default Re: Next Years Power Tour Car Part 2
Some good things happened today.................Good stuff.....The wiring harness arrived from Speartech......and....as usual ....John did a beautiful job......Plug and Play.......Then the headers showed up.......got one side installed before it got to be Nap time......The headers are full length Flowmasters and I got the passenger side in with just a few minor issues....I'll work on the Drivers side tomorrow.........
On the downside.......The Griffin Radiator I ordered (it was originally ordered to replace the unit in my 66 Impala LS powered car) was of a stock radiator hose configuration which worked in the Impala.........But......after getting the radiator roughly located and positioned in the car for the first time.......It was obvious that the angled air inlet of the LSA engine and the upper hose were fighting for the same space.........Darn!!!..........So I ordered another Radiator from Griffin.......except this one is designed for the LS with both hose fittings on the passenger side and is of a crossflow design...........Oh well......Back to plan "A" and it will go in the Impala and the new one for the Chevelle......
Ken
Old 11-23-2013, 01:55 PM
CC Rider's Avatar
CC Rider CC Rider is online now
Shiny Header Guy
Rick
1966 Chevy Caprice 427-390
Old 11-24-2013, 03:23 AM
IM RARE IM RARE is offline
them to pretty to put on the car hang on wall for wall art LOL
Old 11-24-2013, 12:56 PM
I got the driver side Flowmaster header installed.........It wasn't as simple as the passenger side........Seems Flowmaster forgot about the lower control arm mounting bracket on the Drivers side.........Had to remove a good sized chunk of the bracket to clear the pipe......structurally is won't matter.....But!!!.......for what they charge for them , they should fit without any mod's.......and .....my engine is about 3/8 higher than using stock adaptor plates.......So.....it would have been much worse with the header if the engine was lower.......I also have to rework the trans crossmember as the collectors run right into it.........
On the good side........installing the Speartech harness on the engine took about 5 minutes.......Great Job Speartech.......everything marked and labeled perfectly.........
Old 11-24-2013, 02:20 PM
CC Rider's Avatar
Rework guy! [img]<<GRAEMLIN_URL>>/biggthumpup.gif[/img]
Rick
Old 11-24-2013, 05:01 PM
I made some new brake lines today as the Headers were right against the lines in the front.......That Eastwood flaring tool paid for itself today.......
Brakeline and Voltmeter Guy!!
Old 11-24-2013, 11:00 PM
[img]<<GRAEMLIN_URL>>/beers.gif[/img] [img]<<GRAEMLIN_URL>>/headbang.gif[/img]
Old 11-25-2013, 11:51 PM
After getting the Headers installed the other day.......another little issue popped up........LOL.......The collectors went right thru the trans crossmember..........Always something...........As long as I had to modify it .....I added some reinforcement plates to the areas welded previously.........It is now in to stay....(I hope).......Also I put the coil pac's back on and realized the factory spark plug boots aren't going to work.....so I ordered some new ones........always something......
Ken
Old 11-25-2013, 11:58 PM
Canuck's Avatar
Canuck Canuck is offline
Not much left of the original crossmember!!! Its all original except fot the right part, the left part and some of the middle!
www.vancouverclassiccars.com
Old 11-26-2013, 12:03 AM
