Old 01-23-2014, 11:11 AM
kwhizz kwhizz is offline
Default Re: Next Years Power Tour Car Part 2
Until the wheels and tires get here .........the car is still sitting on Jack stands..........I've had a major problem I have been chasing for a week and finally figured it out.....After getting the car started and to get the trans filled.......I was going to run the trans thru the gears and get the fluid flowing to set the proper level........as I clicked the car into gear......it started shaking violently.........WTF!!!..........Scared the heck out of me.............I've never had this happen before.......Humm!!!.....I got a brand new driveshaft assy.......Hummm!!!.......So......I start the car again and click it into gear and look under the car.......and the rear axle assy is bouncing all over the place........HUmmm!!!.........So.....I start thinking about it and come to the conclusion that it is driveshaft related..........Now!!!........My drive line angle to driveshaft was a little more than I would have liked so I figured the universals were fighting each other as the pinion angle wasn't set and I thought that maybe I was at that point of nothing was in scync.....So.......I go ahead and raise the back of the trans to get te trans/driveshaft angle down to 3 degree's........Great.........Get everything put back together.....start the car and it still almost shook itself off the jack stands............Shut everything off and get under the car and turn the driveshaft by hand and as it was being rotated it would bind up and after putting some effort into it , it would snap past the bind point and rotate smoothly........did it again and watched the rear axle assy and I could see it moving as the shaft was going thru the "Bind" spot...........Look closer at the rear universal and I noticed that the Universal joint was installed backwards and the raised contoured portion that the grease fitting was installed in was actually hitting the pinion shaft threads........I pulled the driveshaft out and the theads were smashed in about 1/16" .........Duhhhhhh!!!!!..........I got out my little grinder and ground away the contact area.....put the shaft back in ..........started it up and clicked it in gear and ......smooth as silk.........So......I got the drivetrain angle in the "Sweet Spot" and found the problem.....I replaced both universals cause you just never know......Sometimes this car stuff is hard!!!!......LOL
Old 01-23-2014, 01:16 PM
SS427's Avatar
SS427 SS427 is offline
Whoops....
Rick Nelson
Old 01-23-2014, 02:46 PM
70 Forest Green Zee's Avatar
nice catch and fix &quot;sweet spot guy&quot; [img]<<GRAEMLIN_URL>>/worship.gif[/img]
1970Camaro Z28
Old 01-23-2014, 08:39 PM
IM RARE IM RARE is offline
you should have brought it back to the pros that built the shaft for you ...been there done that also... but hey you paid good money to get the shaft
Old 01-23-2014, 11:51 PM
<div class="ubbcode-block"><div class="ubbcode-header">Originally Posted By: IM RARE</div><div class="ubbcode-body">you should have brought it back to the pros that built the shaft for you ...been there done that also... but hey you paid good money to get the shaft </div></div>
I did!!!!......
Old 01-24-2014, 03:13 AM
<div class="ubbcode-block"><div class="ubbcode-header">Originally Posted By: kwhizz</div><div class="ubbcode-body"><div class="ubbcode-block"><div class="ubbcode-header">Originally Posted By: IM RARE</div><div class="ubbcode-body">you should have brought it back to the pros that built the shaft for you ...been there done that also... but hey you paid good money to get the shaft </div></div>
I did!!!!...... </div></div> tony make it for you
Old 01-24-2014, 11:55 AM
<div class="ubbcode-block"><div class="ubbcode-header">Originally Posted By: IM RARE</div><div class="ubbcode-body"><div class="ubbcode-block"><div class="ubbcode-header">Originally Posted By: kwhizz</div><div class="ubbcode-body"><div class="ubbcode-block"><div class="ubbcode-header">Originally Posted By: IM RARE</div><div class="ubbcode-body">you should have brought it back to the pros that built the shaft for you ...been there done that also... but hey you paid good money to get the shaft </div></div>
</div></div>
Yep!!!.......Just a simple assembly mistake......
Old 01-24-2014, 09:34 PM
them guys should not make them kind of mistakes Just saying just us normal guys LOL was the front one backwards also tuff to grease when they are in backwards you should be all ready to get the Heck out of here for awhile !!
Old 01-25-2014, 10:44 PM
I spent the day today getting a bunch of Radiator hoses cut and fit...........I'm gonna be gone for a couple of weeks and when I get back the wheels and tires will be sitting waiting to be installed.......So.....the list of things that remain to be finished are......get the rear speakers installed......hook up the power wires to the power antenna.......Bleed the brakes one more time.....Get the Exhaust system installed .......and get the front end aligned.........heres a pic of the wheels....
Old 01-26-2014, 03:21 AM
CC Rider's Avatar
CC Rider CC Rider is offline
Hurry back.
Rick
1966 Chevy Caprice 427-390
