Old 05-21-2015, 04:39 PM
VintageMusclecar's Avatar
Default Re: More Chevelle updates
Trans is <span style="font-style: italic">almost</span> in...trying to find that last .001&quot; of wriggle room to get the input shaft to go into the pilot bushing...going to have my lovely assistant Rachel work the clutch while I try to get the trans wriggled the rest of the way home.
Four things to note so far:
1) This trans is HEAVY!
2) This trans is BIG!
3) It looks like the shifter is going to fit the factory opening pretty well.
4) I don't advise doing this solo with the car on jack stands unless you're a good bench presser.
More shortly...I hope.
Old 05-21-2015, 04:41 PM
Hi to Rachel!
Old 05-21-2015, 05:48 PM
Success!
Now I need to figure out what trans mount this thing requires, acquire said trans mount, then see what I need to do to get the crossmember back in.
The shifter location appears to be spot-on.
Here's the new MW CM pinion yoke next to the OEM unit:
I tried to get the yokes swapped out so I could measure for the new driveshaft but I ran into a small snag--I need to get a new pinion nut to work with the MW yoke. The factory 1 1/4&quot; nut is too big and the socket won't fit in the well of the yoke. I need to pick up an aftermarket 1 1/8&quot; nut from Kammers this afternoon (hoping they have one in stock!)
More soon, but I'm off to get cleaned up. Rachel and I are finally taking a (partial) day for ourselves and we're going to Kil-Kare tonight to watch test &amp; tune...if it doesn't rain. [img]<<GRAEMLIN_URL>>/rolleyes.gif[/img]
Old 05-21-2015, 07:10 PM
67 Nova Boy's Avatar
Go Eric Go!! [img]<<GRAEMLIN_URL>>/worship.gif[/img]
Dave
67 Nova Boy
Old 05-22-2015, 03:11 AM
Awesome Eric. You are a great inspiration for making lemons into lemonade.
Keep up the good work,
Jason
Old 05-22-2015, 06:35 PM
Ever get that feeling that you're being ****ed with by inanimate objects? [img]<<GRAEMLIN_URL>>/crazy.gif[/img]
Picked up the new pinion nut from Kammers yesterday on the way to Kil-Kare. I crawled under the car this morning to install the new MW yoke, and the nut absolutely refused to start on the threads.
<span style="font-weight: bold">W</span>hiskey
<span style="font-weight: bold">T</span>ango
<span style="font-weight: bold">F</span>oxtrot
[img]<<GRAEMLIN_URL>>/mad.gif[/img]
Pull the yoke back off, the old nut threads right on...new nut barely goes 1/4 turn and that's it. Long story short, the threads on the pinion were slightly boogered up from the factory nut. I hop back onto Al Gore's intrawebz and after a couple of quick searches find out that the pinion thread is 7/8-16...an oddball size, wouldn't ya know?!? [img]<<GRAEMLIN_URL>>/rolleyes.gif[/img]
Burning up the phone lines to try to find a die of said size--check the local high-end tool emporium...nope, not in stock. Check Kammers, no luck there either.
SO...I crawled back under the car, and wound up using the new pinion nut to chase the threads on the pinion;
Clean the threads on the pinion &amp; nut, oil both, start the nut, give it 1/8 turn with the ratchet, remove, clean everything and start the process over. After ~10 minutes I finally have the threads cleaned up.
So I slide the new yoke back in place, put the washer in place, start the nut, then run it down snug with the ratchet.
Since the rear has a solid pinion spacer instead of a crush sleeve, the nut gets torqued to 125 lb.ft. I set the torque wrench, slip the socket over the nut, and wouldn't you know it, there's not enough room to swing the torque wrench before the end hits the floor.
As Clint Eastwood said in &quot;Heartbreak Ridge&quot;, <span style="font-style: italic">&quot;You adapt. You overcome. You improvise.&quot;</span>
Suffice it to say the nut's torqued. (almost as tightly as the owner by this point...)
Driveshaft has been ordered from Mark Williams, should be a week or so out. That should give me enough time to get the crossmember and speedometer cable figured out.
Not sure if I'm going to put an X-pipe back in the car at this point or not. That's something I'd planned to test on the chassis dyno once all the other bugs had been worked out, but obviously that plan didn't work out. I'm thinking about going to a conventional dual system for now just for simplicity's sake, and maybe later on down the road I'll make up another x-pipe to test it against.
More eventually.
Old 05-22-2015, 06:47 PM
napa68 napa68 is offline
Your car sounds like a passionate Italian woman I used to be friendly with. A great ride but you earned every bit of it in combat[img]<<GRAEMLIN_URL>>/beers.gif[/img]
Old 05-22-2015, 06:59 PM
This is precisely how I feel at this point:
<object width="425" height="350"> <param name="movie" value="https://www.youtube.com/v/UD40W81eTDE"></param> <param name="wmode" value="transparent"></param> <embed src="https://www.youtube.com/v/UD40W81eTDE" type="application/x-shockwave-flash" wmode="transparent" width="425" height="350"> </embed></object>
Old 05-22-2015, 07:00 PM
markinnaples markinnaples is online now
<div class="ubbcode-block"><div class="ubbcode-header">Originally Posted By: napa68</div><div class="ubbcode-body">Your car sounds like a passionate Italian woman I used to be friendly with. A great ride but you earned every bit of it in combat[img]<<GRAEMLIN_URL>>/beers.gif[/img] </div></div>
That. Was. Great.
John 10:30
Old 05-22-2015, 10:13 PM
earntaz earntaz is offline
Eric -- if you had been in my neck of the woods ... I would have lent you one of my thread files!!@#$ TAZ
