Old 02-15-2016, 10:56 PM
earntaz earntaz is offline
Default Re: 57 Nomad Project.........
Aaaaah -- he is stirring ...
Old 02-15-2016, 11:34 PM
70 Forest Green Zee's Avatar
&quot;spoiled Brat&quot; [img]<<GRAEMLIN_URL>>/naughty.gif[/img]
1970Camaro Z28
Old 02-16-2016, 12:50 PM
<div class="ubbcode-block"><div class="ubbcode-header">Originally Posted By: 70 Forest Green Zee</div><div class="ubbcode-body">&quot;spoiled Brat&quot; [img]<<GRAEMLIN_URL>>/naughty.gif[/img] </div></div>
Ya' think? [img]<<GRAEMLIN_URL>>/haha.gif[/img]
Old 02-17-2016, 12:57 AM
kwhizz kwhizz is offline
O.K.........Back at it..........Made a simple mounting plate for the control modules out of 1/4&quot; plastic........Then I got it mounted in the fender well area so it is basically out of the way......Gonna make a mounting bracket for the GM supplied engine compartment fuse box.......I also got the trans cross member bolted in and got the engine drivetrain angle set......Need to make a couple 2 degree angle blocks to change the pinion angle to match the engine.......I also spun the engine over today to get some oil pressure......after getting all the wiring finished up next week I still need to deal with the fuel system......among other things....but...we are getting closer
Old 02-17-2016, 12:14 PM
Wait! I see a few extra holes in that plastic piece....you are gonna fill-in them holes and sand smooth, YES? [img]<<GRAEMLIN_URL>>/naughty.gif[/img] [img]<<GRAEMLIN_URL>>/biggthumpup.gif[/img]
Old 02-19-2016, 01:44 AM
Before I could finish up the engine compartment wiring......I had to close up the fresh air vent openings in the Firewall after removing the vent tubes for mounting space for the control modules......So....I made a couple plates to seal the holes today......Got the passenger side installed (LOL...No room to get at the upper screw as it is right behind the A/C unit.....Took awhile)......And........While I was at it.....I had another issue that was making me crazy.....After getting the basic engine wires hooked up, I turned the key to start and expected the engine to crank over......Nothing.......Humm!!.....Checked the wires at the neutral safety switch.......Power there.......Solenoid wire at the starter.....no power.....Call the Tech Line at American Autowire and explain the situation.....I was told to check the plug where the wire goes thru the firewall......I forgot about that....and it's tucked up behind the A/C unit......(Damm that thing)....finally get it to where I can see it and noticed that the power terminal wasn't snapped into the plug body all the way and when I plugged it in it pushed the spade out.......Duhhhh!!!! Starter now works correctly....also got the GM supplied engine compartment fuse panel installed .......and Time for a Nap!!
Old 02-19-2016, 03:25 AM
Glad that you got it figured out!
Old 02-19-2016, 09:36 PM
69VN's Avatar
69VN 69VN is offline
How to spot a '57 Chevy body style at a glance...
I currently own a 1969 Camaro SS350. Although the original drivetrain is long gone, this 4/speed car has a March '69 HC coded block with #041 heads. The transmission is an M20 Muncie #660 case and the rearend is a BS coded 12 bolt posi. Built in Van Nuys.
Old 02-21-2016, 07:58 PM
Got the drivers side fresh air vent cover plate installed.......I added a slotted area for the harnesses that needed to go inside the car......worked out perfect, after proving everything out I will seal it up with urethane........I also got the Dakota Digital gear sensor installed and hooked up inside the car along with a couple loose ends.....so.....all the wiring is completed inside the car......I just have to get the drive by wire pedal installed........so I decided to get the A/C and Defroster vents installed and put the gauge cluster back in.......everything works......even the check engine light (MAF) sensor not installed along with the gas pedal plug)........Getting Closer......Here are a bunch of Pic's
Old 02-21-2016, 09:21 PM
SS427's Avatar
SS427 SS427 is offline
Damn that is going to be a nice ride!
Rick Nelson
