Thanks Sam,
I am not a GTO expert, but I think Starlight Black was on the list for 69. Not Spcl order, and I like it...
Dana MBTMF |
More pics. Orig air cleaner, sway bar, intake and starter?
Dana MBTMF |
Trying to add more but it will only take jpg not jpeg?
Dana MBTMF |
GTO trim tag
Dana MBTMF |
Engine vin matches car, heads are dated correct as well as intake, has Edelbrock intake now with MSD ignition, headers, came with 750 Holley, looking for quadrajet, trans vin matches. Pans and frame are dry and nice, glass orig except for windshield, owner said it ran when parked. We will see. Turns over nice. Block close-up shows vin to the left and numbers to the right 026975 ? and WT stamp below those. Anyone know what the 5 stamped on the trim tag is?
Dana MBTMF |
Plates still good for car.
Dana MBTMF |
Cool! Looking good so far Dana!
Mark 1966 L72, 4spd Caprice 1974 Z28, M40 Camaro |
<div class="ubbcode-block"><div class="ubbcode-header">Originally Posted By: 427freak</div><div class="ubbcode-body"> Block close-up shows vin to the left and numbers to the right 026975 ? and WT stamp below those. Anyone know what the 5 stamped on the trim tag is? </div></div>
The "5" is most likely an inspector's stamp. Shouldn't the VIN be down at the bottom, front of the block, not on the top by then EUN (engine unit number and WT engine code)? ![]() ![]() |
The Fremont plant did not always put the VIN down in the standard position next to the timing cover. I have had two Fremont cars and the VIN was below and to the left of the two letter engine code.One was a 69 and the other was a 70.
<span style="color: blue">1970 GTO Judge Ram Air IV, 4 speed</span> |
<div class="ubbcode-block"><div class="ubbcode-header">Originally Posted By: 427freak</div><div class="ubbcode-body">Trying to add more but it will only take jpg not jpeg? </div></div>
If you figure this out please let me know.... I can't post pics from my IPhone any more:-( probably operator error:-) Ryan
1969 Beaumont 350 Auto White Sold 1969 Beaumont 307 Auto Green Sold 1969 Chevelle SS 396-L35 Auto Blue Sold 1969 Oldsmobile Cutlass 'S' Sports Coupe W31 |
Thread Tools | |
Display Modes | |
