Old 02-20-2016, 05:35 AM
427freak 427freak is offline
Default Re: GTO Barn Find
GTO trim tag
Dana
MBTMF
Old 02-20-2016, 06:07 AM
Engine vin matches car, heads are dated correct as well as intake, has Edelbrock intake now with MSD ignition, headers, came with 750 Holley, looking for quadrajet, trans vin matches. Pans and frame are dry and nice, glass orig except for windshield, owner said it ran when parked. We will see. Turns over nice. Block close-up shows vin to the left and numbers to the right 026975 ? and WT stamp below those. Anyone know what the 5 stamped on the trim tag is?
Dana
MBTMF
Old 02-20-2016, 06:44 AM
Plates still good for car.
Dana
MBTMF
Old 02-20-2016, 06:49 AM
mssl72's Avatar
mssl72 mssl72 is offline
Cool! Looking good so far Dana!
Mark
1966 L72, 4spd Caprice
1974 Z28, M40 Camaro
Old 02-20-2016, 06:59 AM
Thanks Mark
Come on over and help me kill spiders, creeping me out... [img]<<GRAEMLIN_URL>>/no.gif[/img]
Dana
MBTMF
Old 02-20-2016, 01:16 PM
njsteve njsteve is offline
<div class="ubbcode-block"><div class="ubbcode-header">Originally Posted By: 427freak</div><div class="ubbcode-body"> Block close-up shows vin to the left and numbers to the right 026975 ? and WT stamp below those. Anyone know what the 5 stamped on the trim tag is? </div></div>
The &quot;5&quot; is most likely an inspector's stamp. Shouldn't the VIN be down at the bottom, front of the block, not on the top by then EUN (engine unit number and WT engine code)?
Old 02-20-2016, 02:05 PM
DaJudge DaJudge is offline
The Fremont plant did not always put the VIN down in the standard position next to the timing cover. I have had two Fremont cars and the VIN was below and to the left of the two letter engine code.One was a 69 and the other was a 70.
<span style="color: blue">1970 GTO Judge Ram Air IV, 4 speed</span>
Old 02-20-2016, 02:41 PM
Tracker1's Avatar
Tracker1 Tracker1 is offline
Nice Dana - great find! Built a month before mine - mine is the earliest Ram Air car known, 12D. Similarly equipped as yours except mine no P/S, no disc brakes - great replacement for going to the gym. And the Ram Air engine of course. Clean yours up and drive it - beauty!
Old 02-20-2016, 04:41 PM
<div class="ubbcode-block"><div class="ubbcode-header">Originally Posted By: DaJudge</div><div class="ubbcode-body"> The Fremont plant did not always put the VIN down in the standard position next to the timing cover. I have had two Fremont cars and the VIN was below and to the left of the two letter engine code.One was a 69 and the other was a 70. </div></div>
Neat info. I learn something new every day!
