Old 03-16-2016, 07:49 PM
Default SHOT BLASTING !!!....OEM Intake Manifolds
I have no way to prove my thoughts..........but Im thinking that some/many/most old school OEM Winters Intake Manifolds
were shot blasted with metal media after casting.
I am not a fan of the cosmetic look when sand cast intakes are glass beaded.
Does anybody have experience or knowledge of: 1) Vibratory Tumbling (What Media) of OEM Sand Cast Intakes, Sand Cast Muncie Cases
2) Shot Blasting, Wheelabrator of Sand Cast Intakes and Trans Case
Thanks for your sharing your thoughts and suggestions
Chuck Sharin
[email protected]
69 Camaro COPO "recreation"
Old 03-16-2016, 11:55 PM
Donnie's Avatar
Donnie Donnie is offline
Default Re: SHOT BLASTING !!!....OEM Intake Manifolds
Chuck, I run my intakes thru a wheelabrator. heres a couple pics.
69 SS L78 Chevelle
70 SS 396 Chevelle
The Following User Says Thank You to Donnie For This Useful Post:
CamarosRus (01-22-2025)
Old 03-17-2016, 12:45 AM
Donnie, Thanks for the reply along with pictures............however the FLASH washed out any detail.
Can you provide us with any detail on the exact sized media used ?
Any damage to machined surface or reason to protect ??
Thanks
Chuck Sharin
[email protected]
Old 03-17-2016, 12:46 AM
68l30's Avatar
68l30 68l30 is offline
Vibratory media tumbled Alt case....with and without flash. Same results with intakes and valve covers. Media is a 3/8 thick by 3/4 triangular shaped stone, I run it as "wet" as I can with H20 and a light oil/ rust inhibitor. While not needed with aluminum, it helps keep the media wet and lathers up nicely.
BIG
Old 03-18-2016, 05:43 AM
BanditoJr BanditoJr is offline
If your looking for the original finish and "shine" with some added protection take a freshly blasted part, spray it down with Purple Power (castrol super clean) and then with hot water and an SOS cleaning pad rub the intake untill the rough finish is smoother, but not too much...rinse with water and blow dry. Like new appearance.
Old 03-22-2016, 07:12 AM
They were put into a vibrating tumbler with steel shot- it removes the "green" sand and burnishes the casting sealing the pores and giving it the sheen.
Old 01-22-2025, 03:03 AM
I would sure like proof that NEW Winters Intakes were Tumbled in Steel Shot .........as I "think" Manifolds were placed on a large Diameter steel table and the table rotating inside
an enclosure while metal shot is being hurled at the parts................
Chuck Sharin
[email protected]
