#11
The latest issue of Hot Rod Magazine has a tech article about cams and lifters, both curves and tapers. I have not read it yet, just a passing glance in yesterday's mail.
Mike |
#12
Just checked some this morning. Results:
GM NOS - .0015" crown (100" R) Crower Aftermarket - .0020" (62" R) Used GM Solid - .0005" - .0008" crown So it seems the claim of original GM at 120"R could be correct. Next step is to program and try a re-cut. Paul
70 Camaro LA Z-28 03B Citrus Green LT-1 M-40 3.73's 69 Camaro X-77 Z-28 10C Cortez Silver M-21 3.73's Deluxe Project X - SOLD 69 Camaro X-77 Z-28 01B Garnet Red w/Black top, M-20 3.73 Deluxe Houndstooth |
#13
Just the (constant) load of the oil pump is enough to keep the cam pulled rearward in the block.
"Knowledge is good" Emil Fabor 67 L/78 Camaro SS/RS H-H,1W,2LGSR,3SL,4K,5BY. (Sold) 70 L/78 Nova M-21,Black Cherry,Sandalwood Int. 09 Pontiac G8 GT Premium,Sport,Roof. Liquid Red. |
#14
This sounds like an awesome experiment. I'm excited to hear the results.
#15
From the center (high point) to the outer lip there should be .0021 difference.........That is with a standard dia lifter.........don't think you can get the micro polish required by turning and polishing.......I'm sure GM uses some sort of a orbiting lapping procedure.....
Ken
![]() The Best things in life......Aren't Things |
#16
A .0021" difference in heights yields around a 60"R. It appears from the lifters I have seen the face is ground with some sort of orbital wheel while it is being swung on the radius, all while the lifter is rotating. I think a 60" radius would be a good place to start with this experiment.
I have read where it is recommended to polish the new lifter face with 600 grit paper to aid in break in. The only unknown is the turned finish I will get with the carbide tooling and if polishing can give a finish comparable to the stock lifter. Paul
#17
I think this is going to get interesting ... TAZ [img]<<GRAEMLIN_URL>>/dunno.gif[/img]
#18
<div class="ubbcode-block"><div class="ubbcode-header">Originally Posted By: L78steve</div><div class="ubbcode-body">Just the (constant) load of the oil pump is enough to keep the cam pulled rearward in the block. </div></div>
If that were the case there would be no need for a thrust plate or thrust button on an engine equipped with a roller cam. |
#19
<div class="ubbcode-block"><div class="ubbcode-header">Originally Posted By: VintageMusclecar</div><div class="ubbcode-body"><div class="ubbcode-block"><div class="ubbcode-header">Originally Posted By: L78steve</div><div class="ubbcode-body">Just the (constant) load of the oil pump is enough to keep the cam pulled rearward in the block. </div></div>
If that were the case there would be no need for a thrust plate or thrust button on an engine equipped with a roller cam. </div></div> Exactly. Unless there is a remote oil pump installed. Think about it the angle cut of the pump/Dist. drive gear will thrust the cam rearward. If I'm wrong please tell me why.
#20
It may be that during extreme engine de-acceleration, such as a shift, that the cam may walk forward when using roller lifters, as the pump may be driving the cam during that very short period. I would think otherwise driving the oil pump would be enough to keep it in contact with the thrust face.
Paul
Thread Tools | |
Display Modes | |
