Old 10-02-2016, 07:06 PM
L78racer L78racer is offline
Default Re: More Chevelle updates
I went through this on a BB Nova. Tried several diaphram plates and discs. Then I went to talk to Paul Mercure of Team Checkmate .
He told me to use a Borg & Beck three finger style pressure plate. I bought the setup from Ram and my problems were over.
Old 10-02-2016, 07:35 PM
VintageMusclecar's Avatar
Do you have the details re: the pressure plate & disc that you used?
Old 10-02-2016, 07:56 PM
napa68 napa68 is online now
Eric,
I have this in my Nova
http://www.mcleodracing.com/index.ph...twin-disc.html
Admittedly, my car is lighter than yours. I'm really happy with the drivability and it holds the 600hp well my car makes on MT drag radials.
Tim
Old 10-02-2016, 08:55 PM
I was specifically advised against the RST because it's not intended for use with sticky tires. The RXT was recommended instead.
http://www.mcleodracing.com/index.ph...pns-41077.html
I'm going to inquire about a Soft-lok clutch tomorrow. With the drag radials, my power and weight, there has to be a &quot;weak link&quot; in the system somewhere or it's going to break parts. Since you can't &quot;slip&quot; a drag radial tire like you can a bias slick to absorb some of the initial hit, it has to be absorbed by the clutch. In my case, it <span style="font-style: italic">has to</span> slip a little bit on the initial hit, but lock up once the vehicle is in motion.
Here's a good read on the Soft-Lok over on the Chevelle site:
Click here
Old 10-02-2016, 11:01 PM
<div class="ubbcode-block"><div class="ubbcode-header">Originally Posted By: VintageMusclecar</div><div class="ubbcode-body">Do you have the details re: the pressure plate &amp; disc that you used? </div></div>
Sorry no. This was in 2001 and that car is gone. I can't find the receipts.
Another thing he recommended was to have more gear. I had slicks with 4.10 gear. I was running a Muncie M20. I wanted to keep the 4.10's so I bought a Richmond T-10 with 2.88 first gear when I put the new Ram clutch in.
Old 10-03-2016, 12:11 AM
Alss's Avatar
Alss Alss is offline
I'm using the street slayer from http://americanpowertrain.com/ stands up to my 630 hp BBC and T 56
1969 Beaumont 540 th400 3.70
1968 Camaro ragtop LSA ZL1
Old 10-03-2016, 07:08 PM
I dropped off the clutch at Dayton Clutch &amp; Joint this morning. It appears the pressure plate can be rebuilt &amp; re-surfaced and the flywheel can also be re-surfaced.
After MUCH detective work and a number of phone calls (including to Ram), I ordered another clutch disc--a RAM # 6130--to try with my existing pressure plate &amp; flywheel. This one is a solid step up from the last disc, but it's a dedicated race clutch. It does have a sprung hub to help (at least a little bit) with street manners. Other than that, it's a balls-to-the-wall full boogie race unit.
I *may* have everything back tomorrow, and it shouldn't take too long to get everything back together in the car.
God knows I've got enough practice at it.
Old 10-03-2016, 07:14 PM
Friday Wx is looking good.....
Old 10-05-2016, 03:28 AM
The new clutch is in. I still have to re-mount the shifter and reinstall the shifter bezel, but I'll do that tomorrow. I also have to replace the power steering belt that flipped itself over @ the track, but that's a non-issue.
I did verify with Ram that the new clutch does <span style="font-weight: bold"><span style="text-decoration: underline">not</span></span> technically require any break-in period, but he did say giving it a little time to seat in wouldn't be a bad idea.
Road report possibly tomorrow.
*edit*
I had some help tonight--Eric &amp; Martin (Orange GTO and black `66 Chevelle, respectively) stopped by to help get the car buttoned back up. Eric took a pic &amp; posted it to Facebook.
Old 10-05-2016, 03:36 AM
Sounds promising ersatz clutch guy! [img]<<GRAEMLIN_URL>>/headbang.gif[/img]
