Old 10-15-2016, 03:13 PM
ImpalaAndy ImpalaAndy is offline
Default Re: Andy's 66 Caprice LS Conversion Upgrade
Boy are you quick.
Old 10-15-2016, 04:00 PM
Crush Crush is offline
<div class="ubbcode-block"><div class="ubbcode-header">Originally Posted By: ImpalaAndy</div><div class="ubbcode-body">Boy are you quick. </div></div>
X2!!
Old 10-15-2016, 04:29 PM
I just realized I am being &quot;Overhauled'
Old 10-15-2016, 05:10 PM
kwhizz kwhizz is offline
Just about finished under the car.......By moving the trans cross member back a couple inches, it now made the E-Brake cable way too long.........had to cut it to suit and make a new stop feature for locking the cable........worked out perfectly.....
The transmission cooler lines are in and installed......Just needs trans fluid......
Also got the heater valve and lines finished up also......
Old 10-15-2016, 09:46 PM
KM265S KM265S is offline
I had given Dewitt's the information on where the mounting holes needed to be on the radiator I purchased for my `65. Andy's radiator spacer should be the same. Dewitt's evidently did not save these measurements for the next job.
Old 10-15-2016, 11:07 PM
<div class="ubbcode-block"><div class="ubbcode-header">Originally Posted By: KM265S</div><div class="ubbcode-body">I had given Dewitt's the information on where the mounting holes needed to be on the radiator I purchased for my `65. Andy's radiator spacer should be the same. Dewitt's evidently did not save these measurements for the next job. </div></div>
Yeah ,...........They were about a 1/4&quot; off...........I had to elongate the holes to get it mounted......Hydra Boost show up yet ?????
Old 10-16-2016, 12:02 AM
The Hydra Boost set up has not shown up as of yet. I'll be calling on Monday. Almost six weeks since I placed the order. They must be in demand. Hope it gets here soon. I want to really get a chance to drive my Impala before it needs to be tucked away for winter.
Old 10-16-2016, 01:36 PM
Where are you purchasing the Hydraboost from? I'm contemplating the same, and what brake set-uo do you have?
Old 10-16-2016, 02:53 PM
njsteve njsteve is online now
Is the hydroboost a modified version or a stock application for some recent car?
Old 10-16-2016, 05:36 PM
Here you go..........Steve....Don't know........But, My Impala now stop like an Indy Car...........
http://www.hydratechbraking.com/
