Old 03-12-2017, 10:47 PM
Between the TWO large circular openings (Speedo and Tach or Speedo and Gauges)
there is a small rectangular/vertical opening where the Auto Trans Gear position selector sits.....Four Speed cars had this "window" covered by Black Tape (from back side)
Chuck Sharin
[email protected]
69 Camaro COPO "recreation"
Old 03-12-2017, 10:58 PM
L16pilot L16pilot is offline
The factory opening under the "hump" is quite large...I would estimate larger than the hacked hole in your trans tunnel, but that's subjective. Check the inside driver's subraframe rail...there are three punched holes in a triangular pattern where the back drive bracket would mount. Check these holes closely to see if they've been threaded. Only manual trans cars would have these holes threaded. Not proof-positive, but another potential indicator.
Old 03-14-2017, 02:05 AM
David C. David C. is offline
All of those holes around the shifter hole looks like the layout of the spotwelds for the factory shifter hole plate.
Dave C.
