Old 03-25-2017, 06:33 PM
napa68 napa68 is offline
Finally........................got parts back from the powder coater. Now I can get going again.
I tweaked the right side header to give some more room around the frame rail. I also added O2 bugs for fuel injection at a later date. Fresh ceramic coating too!
Powder coated the bellhousing
Reinstalled the clutch.............
Adjustable fork pivot................
And installed the clutch slave......
Old 03-25-2017, 06:39 PM
And then found out I was shipped the wrong clutch fork. Soooooo.........I wait for the right one to be delivered.
I'm changing back to a regular shifter. Of course, the needed work as it was assembled wrong. Plus the fellow I bought it from gave me the wrong 1-2 rod
Now that's set up and adjusted...............
Unfortunately, I wanted to set the engine and trans in today and that will have to wait a bit until the new fork gets here
Old 03-26-2017, 10:58 PM
kwhizz kwhizz is offline
That's what you call getting Forked.........
Old 04-02-2017, 06:43 PM
Ended up using a different slave / bracket / fork combination. It's a sturdier set up and packaged a little tighter. This will help with the headers.
Ready to drop now.................just need a helper!
Old 04-02-2017, 06:56 PM
Looks great!
Old 04-02-2017, 09:58 PM
Gary Anderson's Avatar
Gary Anderson Gary Anderson is offline
Is that a Novak slave setup?
Old 04-03-2017, 03:04 AM
Looking real good Tim. Can't wait to hear this one run.
Old 04-03-2017, 04:43 AM
PxTx's Avatar
PxTx PxTx is offline
Thanks for the update and pics are always great. Neat to see the two juice clutch linkages for the difference.
Paul III
Old 04-03-2017, 11:48 AM
cook_dw's Avatar
cook_dw cook_dw is offline
Agreed on the slave.. I really like the look of the second one.. Let us know how it compares as far as pedal feel. Setup looks killer.
Old 04-03-2017, 11:05 PM
Yes it is Gary. I'll follow up with my thoughts on it after I get it going.
Tim
