Old 05-16-2017, 02:40 AM
ACDELCO427 ACDELCO427 is offline
Default 1970 L78 Nova
Its kinda odd that the vin on the trans is 10 car's off from the vin on the car.
http://m.ebay.com/itm/Chevrolet-Nova...%257Ciid%253A9
Old 05-16-2017, 04:16 AM
cheveslakr cheveslakr is online now
It appears to be 1000 off, XX3021 for the trans, XX4021 vin and block pad. My '66 L72 vette has a block pad one digit off the vin also. I guess it happens. In my case, the block pad is indisputably untouched but it'll always cast a little doubt to be original to the car I suppose.
Old 05-16-2017, 11:21 AM
Thanks for the correction. Its in Canada so I wonder if it can be document. The original color of green with sandlewood interior would look great.
Old 05-16-2017, 12:16 PM
Subject VIN 114270W364021
Transmission stamping 10W363021
If Canadian delivered new, you'd expect the sellers would be onto the GM Canada Paperwork but best check w/ George and Frank to be sure...
https://www.vintagevehicleservices.com/options.html
If Trans stamping digit an original mistake, there may be others in sequence the same?
Old 05-17-2017, 01:06 AM
Something's fishy.....trans stamp is 19W363021 and engine stamp is 19W364021....those were usually stamped at the same time with the same stamp
Bill Pritchard
Old 05-17-2017, 10:57 AM
WILMASBOYL78's Avatar
Question 70 L78 Nova..
"this car was not restored every thing you see is original condition"....OK
..the VIN number issue between the trans and engine is certainly a problem. Looking at the front end you will note the SS emblem is installed upside down on the grill and the headlite bezels have been changed...this car is no virgin. The dark photos make it difficult to really see any details...Canadian documentation will help clear up some questions.
I also see it has the rear sway bar which would be consistent with a late build 1970 car.
Measure twice/cut once.
-wilma
02 Berger 380hp #95
Lots of L78 Novas
Join National Nostalgic Nova!
70 Orange Cooler
69 Camaro
