Old 08-08-2017, 10:52 AM
bergy's Avatar
bergy bergy is online now
Default Cushion grip steering wheel issue
I have an original black cushion grip steering wheel that keeps getting "greasy" on the rubber surface. I clean it off, but then it comes back. I think that this has been discussed before - any fixes for this problem?
Old 08-08-2017, 11:21 AM
m22mike's Avatar
m22mike m22mike is offline
What are you cleaning with ?
Mike
Old 08-08-2017, 01:47 PM
camarojoe's Avatar
Lacquer thinner.
Joe Barr
Old 08-08-2017, 03:07 PM
If you use lacquer thinner, just be careful not to leave it on too long/wipe too much as it will smooth the grain out. I think enamel reducer works well too. I have used orange hand cleaner with pretty good results but it leaves fine scratches.
Jason
Old 08-08-2017, 03:37 PM
----Try mineral spirits......Bill S
Old 08-08-2017, 05:53 PM
Dawn dishwashing detergent works well on this too.
Old 08-08-2017, 10:44 PM
bergy's Avatar
OK - thanks. I tried mineral spirits. It's not greasy (for now). I hung it back on its spot on the wall....... to be continued.
Old 08-08-2017, 11:35 PM
earntaz earntaz is offline
Simple Green -- I've used it in the past and works well ... TAZ
Old 08-09-2017, 12:35 PM
fiveforty fiveforty is offline
Gritty fast orange hand cleaner, works unbelievable.
Old 08-15-2017, 09:52 PM
I second the rubbing or denatured alcohol -
here is a 69 dash pad which was incredibly sticky... used the same procedure on 70-up GM 4 bar steering wheels.
