Old 11-03-2017, 02:56 AM
Hrdlx62 Hrdlx62 is offline
Default Throttle Cable Pics
Hello all, I'm in the finishing stages of a 68 Chevelle build and need a picture of the throttle cable attachment on the carb end of a Holley equipped big block. The car was originally a small block, now has a big block transplanted in it. Need a pic to determine where the cable hooks to the carb. If anyone could post a pic that would be great. Thanks
Old 11-04-2017, 12:20 AM
My main question here is, did Chevy/GM use the large hole on the throttle shaft lever on cable operated applications? I guess I don't a pic for that. Thanks.
Old 11-05-2017, 10:45 AM
This is from a 1969 396/350 HP Chevelle SS - does this help?
Old 11-05-2017, 12:31 PM
Thanks for the reply. it does help some, I'm using a Holley 3310. The pic gives me a pretty good visual clue to the height of the attachment point though. I want to use an L88 dropped air cleaner base and as I understand there is some issues to work around using a non OEM holley carb. Typical hot rodding trial and error. Anyone have a pic using a Holley. Thanks.
Old 11-05-2017, 09:14 PM
L78_Nova's Avatar
L78_Nova L78_Nova is offline
Name:  L78 Holley.JPG
1970 Nova L-78
Original bracket Original main body but not certain about the rest ie. missing the vented bowl. Also tall style intake... pancake is in basement.
Gary
70 Chevelle SS-454 LS-5 M-22
Old 11-05-2017, 11:40 PM
Huh, not in the top hole interesting. Are the bowl vents cut at an angle? Thanks
Old 11-06-2017, 12:05 AM
L78_Nova's Avatar
Yes bowl vents are angle cut.
Old 11-06-2017, 12:34 PM
Ok, thanks
Old 11-06-2017, 08:07 PM
novadude novadude is offline
I think you'll find that there is only one place on the carb where the cable fit naturally. I'm not certain that the Q-jet cable above is correct (it may be, but it looks "off" to me). See how the cable end is tweaked "up" instead of aiming straight ahead?
It operates better when the cable ball stud is inline with the bracket, as shown on the Holley pic.
Old 11-06-2017, 08:17 PM
tunes's Avatar
tunes tunes is online now
1969 L78 Chevelle. Does this help?
Robert
_______________
2023 Stingray Coupe Z51
The Following User Says Thank You to tunes For This Useful Post:
Hrdlx62 (11-20-2017)
