Old 12-27-2017, 07:27 PM
Kramer77 Kramer77 is offline
Default Correct p/n for quadrajet carb 1969 chevelle
So I’ve been researching and learning about the ole quadrajet carb. From what I can decipher the correct number for a 69 chevelle L35 engine is a 7029215 I think. But why couldn’t a 7029207 work. For the numbers breakdown, if the 6th digit is a 0,1, or 2, then that designates Chevrolet. And the 7th digit, if it is an odd number like 1,3,5,7,9 then it’s for a manual transmission. Seems like there would be a few options. I have looked up the 7029207 and see all of them staring it’s for a corvette or Camaro or possibly the 350hp motor. The 7029215 seems to be stated more for the chevelle but I haven’t found any reason for one number or the other. Let me know guys.
Thank
Old 12-27-2017, 07:29 PM
HawkX66's Avatar
HawkX66 HawkX66 is offline
Thank
7029215 is for a 69 L34 (350hp) 4 spd.
Here's a good quote from Camaros.org
"John (Hinckley), and probably one of the foremost authorities on Corvettes, Joe Lucia, and Joe said that yes, "the GM #7029207 carburetor was used for many years as the service carburetor for ALL 1968-69 small blocks".
http://www.camaros.org/forum/index.php?topic=11198.0
Here is a good listing of the numbers:
Rochester Carburetors (Listed in numerical sequence)
P/N Carb Model Year Eng HP Trans Notes
7027200 4MV 1967 396 325 AT early
7027201 4MV 1967 396 325 ST early
7027202 4MV 1967 327 275 AT 1st type
7027203 4MV 1967 327 275 ST 1st type
7027210 4MV 1967 396 325 AT late
7027211 4MV 1967 396 325 ST late
7027212 4MV 1967 327 275 AT 2nd type
7027213 4MV 1967 327 275 ST 2nd type
7027216 4MV 1967 396 325 AT 3rd type
7027218 4MV 1967 327 275 AT 3nd type
7028210 4MV 1968 396 325 AT
7028211 4MV 1968 396 325 ST
7028212 4MV 1968 327 275 AT
7028213 4MV 1968 327 275 ST
7028217 4MV 1968 396 350 ST
7028218 4MV 1968 a396 350 AT
7028229 4MV 1968 327 325 ST
7029200 4MV 1969 396 325 AT
7029201 4MV 1969 396 325 ST
7029202 4MV 1969 350 255 AT
7029202 4MV 1969 350 300 AT
7029203 4MV 1969 350 255 ST
7029203 4MV 1969 350 300 ST
7029204 4MV 1969 396 350 AT
7029215 4MV 1969 396 350 ST
7036200 4MV 1966 396 325 AT A.I.R.
7036201 4MV 1966 396 325 ST A.I.R.
7036202 4MV 1966 327 275 AT A.I.R.
7036203 4MV 1966 327 275 ST A.I.R.
7036210 4MV 1966 327 275 AT A.I.R.
7037200 4MV 1967 396 325 AT A.I.R.
7037201 4MV 1967 396 325 ST A.I.R.
7037202 4MV 1967 327 275 AT 1st type A.I.R.
7037203 4MV 1967 327 275 ST 1st type A.I.R.
7037210 4MV 1967 396 325 AT late A.I.R.
7037211 4MV 1967 396 325 ST late A.I.R.
7037212 4MV 1967 327 275 ST 2nd type A.I.R.
7037213 4MV 1967 327 275 ST 2nd type A.I.R.
7037216 4MV 1967 396 325 AT 3rd type A.I.R.
7037218 4MV 1967 327 275 ST 3rd type A.I.R.
7040200 4MV 1970 402 330 AT
7040200 4MV 1970 454 360 AT
7040201 4MV 1970 402 330 ST
7040201 4MV 1970 454 360 ST
7040202 4MV 1970 350 300 AT
7040203 4MV 1970 350 300 ST
7040204 4MV 1970 402 350 AT
7040204 4MV 1970 454 360 AT
7040205 4MV 1970 402 350 ST
7040213 4MV 1970 350 300 ST
7040500 4MV 1970 402 330 AT
7040500 4MV 1970 454 360 AT
7040501 4MV 1970 402 330 ST
7040501 4MV 1970 454 360 ST
7040502 4MV 1970 350 300 AT
7040503 4MV 1970 350 300 ST
7040504 4MV 1970 402 350 AT
7040504 4MV 1970 454 360 AT
7040505 4MV 1970 402 350 ST
7040505 4MV 1970 454 360 ST
7040513 4MV 1970 350 300 ST
7041200 4MV 1971 402 300 AT
7041200 4MV 1971 454 365 AT
7041201 4MV 1971 402 300 ST
7041201 4MV 1971 454 365 ST
7041202 4MV 1971 350 270 AT
7041203 4MV 1971 350 270 ST
7042202 4MV 1972 350 175 AT, Non-CA
7042203 4MV 1972 350 175 ST, Non-CA
7042215 4MV 1972 402 240 ST
7042220 4MV 1972 402 240 AT
7042902 4MV 1972 350 175 AT, CA
7042903 4MV 1972 350 200 ST, CA
-Dave
Semper Fi!
69 Camaro SS396 L34 X66
Old 12-27-2017, 07:53 PM
Default Quadrajet info.
Wow thanks HAWK. great info that I hadn’t found yet. Appreciate it
The Following User Says Thank You to Kramer77 For This Useful Post:
HawkX66 (12-28-2017)
Old 12-27-2017, 10:26 PM
I've got a 7040204 with a FF after these numbers. I see this number on the list, but what is the FF for? Date is 2969
Old 12-27-2017, 11:09 PM
hiperf69 hiperf69 is online now
The "FF" is the Broadcast code on the build sheet.
It is what ties the parts to the car.
Build sheets only have so much room so each item was given a code.
Carb. W.P.Pulley. P.S.Pulley. Crank Pulley
"FF". "BV". "DD". "AB"
And so on.
Joe
The Following User Says Thank You to hiperf69 For This Useful Post:
big gear head (12-28-2017)
Old 12-28-2017, 12:46 AM
MarcDant's Avatar
MarcDant MarcDant is offline
Thank
FWIW the 7029207 have different float bowl assemblies than the 7029215,the 7029207 is for the 350 ci - 350 HP engine & the 7029215 is 396 - 427 ci application.
Old 12-28-2017, 04:10 AM
Thanks Joe
Old 01-21-2025, 09:51 PM
Chevelle SS 396 L78 Chevelle SS 396 L78 is offline
Glad I found this thread! That Quadrajet Table by p/n and year is amazing! Here’s my question: I bought a ‘67 Chevelle SS 396/325 TH400 car with the original engine (never been out of the car apparently), but it has a replacement Quadrajet by Carter p/n 7029202 (same for Chevelle, Camaro, etc).
Apparently, this replacement carb was installed at some point by removing the Quadrajet my engine was born with. My car was assembled in Atlanta the 3rd week in May 1967, and the engine was assembled May 10th at Tonawanda, NY.
So, which Quadrajet carburetor would have been on my engine from the factory? It has to be one of 3 models: 7027200 (early), 7027210 (late) or 7027216 (3rd Type)?
I have researched this as far as possible, but I haven’t found anything with respect to when each type of ‘67 Rochester Quadrajet of the three models were released for production/engine assembly.
Any help on this would be much appreciated!
Thanks,
John
PLEASE NOTE: I started a new thread on this topic, so hopefully more will see it! Thanks!
