Old 02-20-2018, 02:05 AM
L78 Fred L78 Fred is offline
Default 69 Camaro SS L78 Spiral Shocks 3192832 vs 3192851
1969 Camaro SS Shock application question?
02 D Coupe L78 396/375, M40 , 12 bolt 3.55 ,3953219A Pitman, Multi-leaf springs(5)
Correct rear shock 3192832?
04C Convertible L78/375, M21, 12 bolt 4.10, 3958227 Pitman (F41), Multi-leaf springs(5)
Correct rear shock 3192851?
Front for both should be 3192477?
Thank you
Fred
Fred
[email protected]
610-585-4155
WANTED:
1969 396/375 hp JH Vin N6352xx Mid April 69 block 272 casting
Always looking for dated L78 parts from Jan-Apr 69
Old 02-20-2018, 03:10 PM
William William is offline
The few Broadcast copies out there indicate automatics were built with TN rear shocks [3192832] manual trans were built with UN rear shocks [3192851].
Not enough data on fronts but 3192477 is common. NOS has been found with original PS labels.
Old 02-20-2018, 11:03 PM
William
Thank You very much for the detailed clarification
Regards
Fred
Fred
[email protected]
610-585-4155
WANTED:
Old 03-21-2023, 12:15 AM
JJR69COPO JJR69COPO is offline
Default 69 Camaro SS L78 Spiral Shocks 3192832 vs 3192851 (vs 3192481)
Does anyone know if front Spiral Shocks Part No. 3192481 came originally on any L78 or L72 T400 69 Camaros?
The 481's on my low miles car are leaking, pitted and have date stamps corresponding to the car's build date which leads me to believe they are originals (along with the other verified original front suspension parts) but everything I read says that BB cars came with 3192477's.
The rear spirals on my car are 3192832's which Willam and at least one other source says are correct.
I'm trying to verify if the 481's are correct before sending them out to be rebuilt.
Thank you,
Jim
Old 03-21-2023, 01:36 AM
X66 714's Avatar
X66 714 X66 714 is offline
Thank you,
Jim
The 481s are the correct shocks for your car as long as it doesn't have F41. Those shocks should be marked "PW". Warren helped me to get the correct shocks for my car....Joe
JJR69COPO (03-22-2023)
Old 03-21-2023, 02:01 AM
Kurt S Kurt S is offline
Yup. PW for BB auto, PS for BB manual.
Kurt S - CRG
The Following User Says Thank You to Kurt S For This Useful Post:
Old 03-22-2023, 01:33 AM
Joe and Kurt,
Thanks for your responses.
Jim
The Following User Says Thank You to JJR69COPO For This Useful Post:
X66 714 (03-22-2023)
