Old 03-28-2018, 09:05 PM
scuncio scuncio is offline
Default '69 COPO Camaro Cowl Air Cleaner
Last weekend I bought a Camaro from a guy who used to own a documented RS COPO years ago. He had installed the original cowl induction air cleaner from the COPO on the car I purchased, and I'd like to understand exactly what I have. It appears to be an assembly line correct flat-bottom base with an incorrect chromed open element air cleaner lid, but with the correct hood sealing flange. Obviously it's a major bummer that the snorkel was hacked but I'm guessing that can be replaced by someone who knows what he's doing.
The decal was a new repop, something the previous owner installed a couple years ago.
Any advice would be much appreciated!
Old 03-28-2018, 10:24 PM
L78steve L78steve is offline
I have a snorkel removed from a over the counter replacement assembly if your interested.
Old 03-28-2018, 10:29 PM
PM sent
Old 03-28-2018, 11:09 PM
Neat piece! Sorry I can’t add any comments... but I’d sure like to hear more about the Camaro you bought!
Old 03-28-2018, 11:58 PM
William William is offline
In production, L34, L35, L78 & both COPOs used the #6485235 air cleaner assembly. Also used on Z/28 with an extension not used on 396/427. So it is not particularly rare.
Sometime after July '69, the base was revised with a bead to raise the lid for better air flow. Some cars built after that time have the revised base. GMPD serviced the 2nd design #6485235 well into the '80s with another revision; a vent tube with 2 45º bends to clear a Holley double-pumper. GMPD also serviced the seal flange but mostly the version used on Chevelles, notched to clear a vacuum pod used on A/C cars.
Your unit has an original flange. The flat-bottom base is a plus but needs a little work and a lid as noted and is rusty. I suspect that isn't the original seal. Were it complete and in excellent original condition, it would be a great find.
Working against you, the flat bottom ZL2 air cleaner, lid, flange and seal are nicely reproduced for about $250.
Old 03-29-2018, 12:20 AM
Does the rubber seal seam have tape on it?
If so,please show it close up & from different angles..
Old 03-29-2018, 12:37 AM
Sometime after July '69, the base was revised with a bead to raise the lid for better air flow. Cars built after that time should have the revised base. GMPD serviced the 2nd design #6485235 well into the '80s with another revision; a vent tube with 2 45º bends to clear a Holley double-pumper. GMPD also serviced the seal flange but mostly the version used on Chevelles, notched to clear a vacuum pod used on A/C cars.
Not to start an argument but I believe the raised bead on the floor of the base is for improved sealing.
I cannot see how that would improve airflow.
Granted the repop is nice but its still a repop.
Old 03-29-2018, 12:39 AM
Does the bottom side of the lid have the silk screening?
Old 03-29-2018, 01:43 AM
Thanks everyone, very helpful. No one is hurting my feelings with candid commentary - I will be looking to sell this to recoup some $ from the car purchase so I’m trying to understand if it’s more sensible to sell it as-is or pay to have it restored.
Steve - yes, the underside of the lid does have the original silk screening.
Old 03-29-2018, 03:06 AM
I believe under certain conditions there was an air flow restriction with the original flat-bottom. Elevating the lid would eliminate the problem.
I have had several flat bottoms and the element sealed to the base just fine.
