Old 04-08-2018, 09:42 AM
Ryan1969Chevelle's Avatar
Originally Posted by Postsedan View Post
Looking Nice
Don't forget to tighten the front sway bar end link.....you have about 3/4 of thread to tighten.
Were your backing plates originally cast or gray....or you just decided to do it that way?
All the steering and suspension bolts are loose, I bought Boe-Shield to protect each bolt and nut, line, clip, etc.
The backing plates, I used advice from a Chevelle expert and then confirmed with an Olds expert, and then confirmed with the Assembly manual:-)
Ryan
Old 04-08-2018, 10:48 AM
Ryan
Chevelle expert
Old 04-08-2018, 01:49 PM
Great progress Ryan, keep rockin'!
Hard to be sure from the pics but are all longest shoes to the rear @ each corner?
Old 04-08-2018, 07:14 PM
Love the picture:-)
Yes, Dave Birdwell helped me over FB to get the right brake parts on the correct wheel:-)
Ryan
Old 04-10-2018, 02:55 AM
I bought a new in the box ACC black carpet set. This carpet is for automatic which I am led to believe is best for Cutlass as the 4 speed hump is small.
I also got up in the night to pee and ended up buying a 1969 442 4 Speed shifter complete with handle and ball. I must have been deprived of shifters as a child :-) (making up for lost time)
Ryan
Old 04-10-2018, 11:32 PM
DW31S's Avatar
DW31S DW31S is offline
Thought you were using the rubber floor covering..?.. and the 442 shifter should have the numerals in/on the stick; W-31s only have the “H”. Not knocking your shifter fetish....I think I’m up to about 6 myself (including Super Shifters and a Ram Rod).
Old 04-10-2018, 11:37 PM
I will use the new carpet with the original shifter hole. I am trying to get the car like it was New (or sort of close to that) and have lots of fun options ready for the next few years.
Extra shifters make me happy :-) Agree Cutlass S has H, this one is 442, it may be for sale after rebuild... TBD.
Ryan
Old 04-11-2018, 10:53 AM
RamblerDealer Terry turned my drums and dropped them off:-) Thanks!!
Ryan
Old 04-11-2018, 10:34 PM
Chop Cut Rebuild W-31 Style :-)
My wait in the que is over, ProTouring Mustang Is done and now Cutlass!!!
Happy to see the bad getting cut out, I couldn’t have done this without someone to work with to learn from.
I had them modify the trunk support, the repop has a huge “hip” on one side now it matches the OEM piece.
Ryan
mockingbird812 (04-11-2018)
  #2620
Old 04-11-2018, 11:25 PM
Keep pluggin’ Ryan. Looking GOOD!
