Go Back   The Supercar Registry > General Discussion > Ford-Mercury
Old 10-20-2018, 06:00 PM
njsteve njsteve is offline
Got all the pistons and rods in today. Plastigage check on each rod bearing clearance was .015. Rotational torque when all eight were installed was 300 inch pounds (25 ft lbs).
Old 10-20-2018, 10:15 PM
Installed the original camshaft back in the engine and degreed it. Since I didn't have a solid lifter to use for degreeing purposes, I wound up disassembling one of the original hydraulic lifters and replacing the inner spring with a 5/16 nut and and reassembling it. It worked great.
I reused the existing timing chain and gears since they had all of 400 miles on them (and 20 years since the dealer installed them).
The factory intake centerline spec is 110 degrees and it turned out to be between 108.75 and 109 degrees. (after three readings). So I guess it is a little over one degree advanced which is perfectly fine with me.
Here's the factory specs on the 460/365 horsepower camshaft:
engine...............lobe lift.....valve lift.........open (btdc)... IN dur...EX dur....overlap.......hp.....................torque .........comp ratio
1971-460(4v).....253/.278...442/.486.......16 deg..........256.......270........36 deg .....(365hp@4600)[email protected]
256°/270° @ SAE
193°/206° @ .050"
.253"/.278" lobe lift (.443/.487 valve lift)
110°/116° lobe centerlines –
113 Lobe Separation Angle
Old 10-21-2018, 07:51 PM
Still at it today. Measured the deck clearance with the dial indicator. Came out to .037. CC'd one of the chambers and got 74 cc's. Installed the cylinder heads, lifters, push rods and a new set of rocker arms. Then installed the intake. It weighs a ton! I think it was almost as heavy as one of the cylinder heads.
Worked out the calculations for compression ratio and it comes to 10.78 to 1. It should be "peppy" as Gramma used to say.
300deluxeL79 (10-22-2018)
Old 10-21-2018, 08:37 PM
Nice! Now that is healthy!!
Old 10-21-2018, 09:42 PM
Thanks!
BTW, in case anyone wonders, the VIN stamp on these blocks is on the rear of the block, just below where the driver's side cylinder heads bolts up.
Old 10-23-2018, 02:26 AM
scuncio scuncio is online now
Pretty stout grind for a stock Lincoln cam!
Old 10-23-2018, 10:58 AM
While GM dumped the compression ratios in 1971 down to 8.5 to 1, Ford (and Mopar) held out to the end. From what I am learning, in 1972, Ford used an 8 degree retarded crank gear sprocket and much larger combustion chambers on the heads to this drop the compression (and horsepower) on the 460, drastically. This was the truly the end of the Cretaceous Period for engines. The power went from 365 to 245 (212 in '73) and torque from 500 to 342 ft lbs. Even with the SAE to net ratings that was still a helluva drop.
That was the main reason I wanted to degree this cam was to make sure the dealer didn't put on the later retarded timing gear set when they did the water pump repair back in 1998. I guess this was the first thing they actually got right at my Dad's local Lincoln dealer.
scuncio (10-28-2018)
