Old 11-27-2018, 02:47 PM
SS427's Avatar
SS427 SS427 is offline
Default Help with Muncie speedo gears
As many may know, our 69 Chevelle when found was missing the M21 so I took one off the shelf that I had (originally came out of a Pontiac) and rebuilt it using the correct Chevelle tailhousing. What I am not sure about is what speedometer drive and driven gear I need for the 4.10 with F70x15 tires. From talking with Eric at Crash Enterprises we came up with a small 8 tooth metal drive gear and a large yellow 24 tooth driven gear when used in conjunction with the .7333 speedo reducer. Can anyone else concur with this information before I put it all back together or offer other insight? I also could use part numbers if you have them.
Another question, does the 69 4.10 car use the offset BW rectangular adapter or the round 90* adapter? Thanks in advance for your help.
Rick
Rick Nelson
Attachments - The Supercar Registry Stewart Warner date chart.jpg IMG_0572.JPG DSC02354.JPG DSC02353.JPG
Old 11-27-2018, 05:01 PM
fsc66 fsc66 is offline
Default Gear clculations
Rick,
will any of this help?
https://www.cartechbooks.com/techtip...e-speedometer/
Paul
[email protected]
Old 11-27-2018, 05:02 PM
x33rs x33rs is offline
I did the math and with an 8 tooth drive gear, and a 27 inch tall tire (746.96 revolutions per mile) it is in fact a 24.47 driven gear that you need.
24 will work fine.
Old 11-27-2018, 05:21 PM
SS427's Avatar
Yes and no. I had been there already and it helped but not completely. The real stickler that I am dealing with is that the car came with F70x15 NOT F70x14 which is a different diameter and it throws a slight wrench into things. Same for the speedo reducer.
Rick Nelson
Old 11-27-2018, 06:21 PM
ssl78 ssl78 is offline
my 69 4:10 Chevelle uses the straight adapter.
69 RS SS L78 conv
69 RS SS ZL1
69 L78 Chevelle conv
69 L78 Nova
69 L34 Nova
67 SS Chevelle
73 Trans Am
Old 11-27-2018, 06:23 PM
SS427's Avatar
Interesting John. M22 or M21? Do you have a photo of the adapter by chance so that I can see what the straight one looks like? Thanks
Rick Nelson
Old 11-27-2018, 06:34 PM
m22 trans. As far as I know the reducer was original but who knows I bought the car in 1991 any thing could have happened before that.
69 RS SS L78 conv
69 RS SS ZL1
69 L78 Nova
69 L34 Nova
67 SS Chevelle
73 Trans Am
Old 11-27-2018, 06:56 PM
SS427's Avatar
Ok, good. That is the same SW piece that I have though I have not confirmed which ratio I need yet with the F70x15. Thanks for posting that John.
Rick Nelson
Old 11-27-2018, 07:53 PM
Would it be the same ratio as a Yenko Camaro. Doesnt Chad have any pictures of his adapter from the blue Yenko Chevelle
69 RS SS L78 conv
69 RS SS ZL1
69 L78 Nova
69 L34 Nova
67 SS Chevelle
73 Trans Am
Old 11-27-2018, 08:15 PM
SS427's Avatar
I haven't had a chance to call and ask him yet. I have several but of course, the one area of the transmission I did not take a photo of was the adapter. Go figure. I got a great shot of the XF trans stamp on the top but no adapter.
As far as being the same as the Camaro I do not know why it would not be. M21, 4.10, F70x15, all things being equal. The gears I posted at the beginning were the Camaro ones but just trying to confirm.
Rick Nelson
