Old 12-30-2018, 06:16 PM
Super job Rick! Since you asked, my KC car had a blue insp. mark on the clutch pedal, and a purple daub on the upper brake pedal. Appears all else is exactly as you've pictured.
On the column, those aluminum washer inserts that have the yellow crash indicator thingys, did you squirt something in there or use a yellow paint? Asking because if I was to assume, I'd say they were filled after the column was installed to get the position correct. I've seen that yellow mold spew out between the aluminum washer and the metal bracket. Didn't know if there was anything available to duplicate this???
Jerry
Old 12-30-2018, 06:23 PM
SS427's Avatar
SS427 SS427 is offline
Jerry
The yellow injected plastic was actually used to hold the shim mounts in place and designed to break loose in case of an accident. When I restored them I heated them up and pushed the plastic out, restored the complete unit and then injected hot melt plastic back into them to hold them. I then had to paint the yellow over the plastic as I could not find yellow hot melt. These were originally injected as a unit before they were installed on the column.
Rick Nelson
Old 12-30-2018, 09:30 PM
Rick, I noticed that you cut out the seal with an exacto knife. Here is something that I found very interesting and might save you a lot of time, and make higher quality parts too. https://www.youtube.com/watch?v=hejUzvfGuY8&t=286s
My wife actually got one of these for Christmas. I had found this video a few weeks earlier and I was excited when I found out she was getting one. When I mentioned how useful it would be to me she got that attitude and said that I would not be using it.
SS427 (01-13-2019)
  #194
Old 12-31-2018, 12:07 AM
WILMASBOYL78's Avatar
Smile 69 Chevelle Restoration...
Rick...not that you need to showcase your skills...but, this incredible story on the Yenko restoration is the best brochure a business like yours could have. Your attention to detail is amazing...and I know a certain gal is helping it to make it truly "one of one'
Karen and I send all the best to you and Annie for a happy and healthy 2019
Tom
02 Berger 380hp #95
Lots of L78 Novas
Join National Nostalgic Nova!
70 Orange Cooler
69 Camaro
Old 12-31-2018, 10:20 PM
SS427's Avatar
I restored the steering column intermediate shaft months ago but thought now would be a good time to post it since I restored the column. The shaft was in pretty rough shape. Somewhat rusty and collapsed from the accident so I had my work cut out for me. I disassembled the entire shaft, determined the finishes that were originally on it, media blasted it and the restored it. I had to reinject the plastic into the shaft after determining the correct length. The original owner has sprayed a lot of the engine compartment with black spray paint so much detective work was used to determine what was original and what was spray canned. After that was done it was all finished and reassembled.
Rick Nelson
Old 12-31-2018, 10:29 PM
Lovely images
Old 12-31-2018, 10:53 PM
chevyman0429's Avatar
Rick that shim or retainer that holds on those 2 square blocks does anyone reproduce these! Very nice job btw and thanks for taking the time to share your build with us!
1969 SS 396 chevelle
1978 chevy shortbed step side
1983 chevy shortbed
1985 chevy shortbed
Old 12-31-2018, 11:33 PM
SS427's Avatar
I have never had to replace one of these so I never checked. I have to believe these would be fairly simple to find however. If you need one i can check my parts bin when i get to the shop and see if i have an extra, just let me know.
Rick Nelson
Old 12-31-2018, 11:37 PM
Yes I do need one! When I pulled my black 69 apart it had broke in half in the accident it was in!
1983 chevy shortbed
1985 chevy shortbed
Old 01-01-2019, 02:45 PM
SS427's Avatar
chevyman, I have only 1 left. PM me your address and I will put it in tomorrows mail. Happy New Year.
Rick Nelson
