Old 01-01-2019, 09:49 PM
madden madden is offline
Default Help decode sbc to606ctb
hi need help to decode what car this sbc would have come from please
0010 block 4 bolt main
sbc
TO606CTB
thx
chris
1970 citrus Yenko Nova
Old 01-01-2019, 10:16 PM
x77-69z28's Avatar
70 Z28: can’t remember if CTB is stick or auto. Built June 6th. Is there a vin stamped by the oil filter boss, or the deck? Would be nice to reunite it with the car if it still exists!
Buddy
Edit. CTB is stick shift, CTC is turbo 400.
The Following User Says Thank You to x77-69z28 For This Useful Post:
madden (01-02-2019)
Old 01-01-2019, 10:29 PM
fsc66 fsc66 is offline
Default See attached page:
http://www.nastyz28.com/gm-chevy-cod...s-suffix-3.php
Paul
[email protected]
The Following User Says Thank You to fsc66 For This Useful Post:
madden (01-02-2019)
Old 01-01-2019, 11:28 PM
ZLP955's Avatar
ZLP955 ZLP955 is offline
Block casting date will help ID it.
Tim in NSW, Australia
Old 01-02-2019, 12:11 AM
ronzz572 ronzz572 is offline
sbc
TO606CTB
thx
chris
It should be a V0606CTB please recheck it? or post a picture? CTB is for a 70 z28 4 speed car. 1970 Z28 motors were built in flint Michigan and begin with a V. The assembly date is June 6th 1970. Also a partial vin should be stamped on the rough cast near oil filter if for a Norwood built car. If it was a Vannuys car it's on the front pad where the stamp your questioning is.
1970 L78 camaro Cortez silver ralley sport under restoration
Old 01-02-2019, 12:13 AM
Tracker1's Avatar
Tracker1 Tracker1 is offline
A Tonawanda built 1970 LT1 Z28 engine? I've never seen one, only Flints with a ' V '
You'd think a guy with a '70 Deuce who has been buying up LT1 parts here in the parts-for-sale section would know.....
Things that make you go hmmmmmm.
I ain't nobody, dork.
The Following User Says Thank You to Tracker1 For This Useful Post:
nova7579 (01-02-2019)
Old 01-02-2019, 01:46 AM
I’ve read that Flint was the only foundry that had the tooling to unshroud the 2.02 valves, so all Tonawanda small blocks were limited to 1.94 and smaller intake valves. Can anybody confirm this?
Owned since 1978 - First Car
Old 01-02-2019, 07:22 PM
YENKO DEUCE REGISTRY's Avatar
CTB is indeed a '70 350/360HP for the Z28's unless it has a Nova VIN which makes it a COPO 9010 application.
Marlin
Old 01-02-2019, 07:59 PM
If the OP relays the rest of the info from this engine, it could end up being one of the other CTB Suffix applications which may also jive w/ the Tonawanda build...72-75 400 SBC or '78 Monza 305?
Old 01-02-2019, 08:33 PM
TRACKER1
i dont need your smart ass remarks...thx
your the kind of guy that drives individuals off sites like this as you believe you know it all.........and have the right to judge other members!
the rest of you members trying to help
the prefix is definitely "T0606CTB" and not "V0606CTB"...and that was why i was questioning it......did not make sense to me
as i stated it is a 1970 "0010" 4 bolt bolt and this is the prefix up on the front pad
i do NOT claim to be an expert/ never have and still learning from some members kind enough to help me
i will try to get a clear pic of the prefix stamping
regards
chris
