Old 02-11-2019, 02:22 PM
Debating here this morning whether I have enough time to install the Crossram and get the carbs setup and tuned before I run out of time. One can spend a couple days messing around with the pedal, cable, fuel lines, the odd leak and carb tuning, but I'm tempted to install it while the front clip is off the car.
I'm back and forth on this one at the moment.
Damien (02-11-2019)
  #142
Old 02-11-2019, 03:06 PM
earntaz earntaz is offline
IMHO ... setup can be a pain in the south end -- but worth it ... get er' done!! Craig
The Following User Says Thank You to earntaz For This Useful Post:
NorCam (02-11-2019)
  #143
Old 02-11-2019, 03:18 PM
outlawperformance outlawperformance is offline
The cross ram setup is an easy tune I can PM you my tuning specs I haven't changed anything after it was setup. Idles all day and blip throttle and its clean and crisp. FYI you'll need to cut down valve cover rails to fit but no biggee. We have similar builds with engine size and cam.
The Following User Says Thank You to outlawperformance For This Useful Post:
NorCam (02-11-2019)
  #144
Old 02-11-2019, 03:24 PM
Crush Crush is offline
[QUOTE=NorCam;1434741]Rounding the corner here with 10 days left to finish it up before the World of Wheels in Calgary. Finished installing the clutch today, added some solid motor mounts, dropped the stroker motor into the Nova and got the headers set. Once everything else is in to surround the motor, it should have a real nice clean look to it. And a nice lumpy solid cam to announce itself with. More later in the week.
You are a machine!
The Following User Says Thank You to Crush For This Useful Post:
NorCam (02-11-2019)
  #145
Old 02-11-2019, 04:33 PM
Tracker1's Avatar
Tracker1 Tracker1 is offline
This thing is going to be tons of fun on the street. Nice build Graeme!
I ain't nobody, dork.
The Following User Says Thank You to Tracker1 For This Useful Post:
NorCam (02-11-2019)
  #146
Old 02-11-2019, 06:21 PM
If you can PM the carb or tuning info you have, that would be helpful. I'm on my way out to the shop now to convert the pedal/cable, and start on the Crossram intake and carbs. Thanks for this.
Old 02-12-2019, 05:17 AM
The Crossram is in fact going onto the new motor. It took a while to find all of the parts, but ended up finding everything tonight. Throttle cable and pedal has now been changed, and I'll now mount the intake in the morning.
Old 02-12-2019, 11:34 AM
That's going to be awesome. This is going to be such a great car when you are done.
NorCam (02-12-2019)
  #149
Old 02-12-2019, 06:40 PM
Intake gaskets are set and I'm ready to mount the Crossram, but first comes the new gauges and a 90 degree fitting for the oil pressure gauge. Forgetting to install this BEFORE you install a Crossram intake will cause you some hardship. Ask me how I know this...lol. Anyway, added the 90 fitting to get the line connected and now I'll mount the lower base. Here's a few pics to update the thread.
Installing the oil fitting ahead of the lower base which overhangs the rear of the block.
You need a 90 fitting back here or the oil line won't fit under the rear lip of the intake as it overhangs the block.
New SW Green Classic Gauges mounted up under the dash.
Xplantdad (02-12-2019)
  #150
Old 02-12-2019, 09:29 PM
GrumpyJeff's Avatar
GrumpyJeff GrumpyJeff is offline
Im digging everything about this thing. I had my eye on that car for a little while before you got. Really neat Car, Great job Dude
