Old 01-24-2019, 11:40 AM
69 Post Sedan's Avatar
Do you have screws in those Kurt?
No screws at all......
1968 Schwinn Orange Krate
1969 Schwinn Pea Picker
1968 Schwinn 5-Speed
1970 Schwinn 3-Speed Deluxe
1973 Schwinn 5-Speed Suburban
All Original Paint Bikes
Old 01-24-2019, 12:41 PM
novadude novadude is offline
How do those M&H Muscle car Drag tires drive on the street? Do the soft sidewalls make them a little squirrely on highway off-ramps, etc?
Old 01-24-2019, 01:18 PM
I don’t notice anything scary.....but that’s all I’ve had on the car for years. First was Mickey Thompson Indy Profile tires for a long time. Then I had ET Street DOT 28x10.5 tires but they only had 8” on the ground. Now I run these....they have 10” on the ground and look the part best. IMO
The Indy Profile tires looked great too....they would stick good at the track but beefed for mercy on the street....lol
The ET Street also looked good but the M&H look and work better.....for me.
The skinnies up front will move around when caught in a wide gap in the road. When I’m on a curve or turning, I try to take my time.....although I’ve been known to “try” and keep up with some friends in the Hot Rod Power tour when it came through Wisconsin....lol
I keep the tire pressure around 28-30 on the roads and 19-21 at the track.
Kurt
The Following 3 Users Say Thank You to 69 Post Sedan For This Useful Post:
dustinm (01-24-2019), markinnaples (01-24-2019), YENKO DEUCE REGISTRY (01-24-2019)
  #14
Old 01-24-2019, 02:14 PM
dustinm dustinm is offline
Another great tread. I am torn between day 2 and modern radials to drive the wheels off mine. Maybe next year I can "justify" a second set with my wife. I am in the middle of a 4L80 install and getting grilled on cost.
Kurt how much room do you have on each side of the tire. With a little ballast I can get mine to hook with G60s, but I also like a full wheel well.
Old 01-24-2019, 03:01 PM
I have plenty of room.....the key is to have the correct backspace. For a 1968-1972 Chevelle, whatever the width of the wheel is, divide in half and add a half inch. For example, an 8” wide wheel needs a 4.5” backspace.....ideally. Most of the 8” wide wheels I’ve found have a 4.25” backspace, which work.
I have a set of 7” wheels with a 4.5” backspace. They work but sit in a little too far. But they do fit.
Kurt
The Following 2 Users Say Thank You to 69 Post Sedan For This Useful Post:
dustinm (01-24-2019), jerry455 (01-24-2019)
  #16
Old 01-25-2019, 03:55 PM
Rumbleguts396 Rumbleguts396 is offline
Hi Kurt, do you run tubes in the M&H tires? Thanks Rob
1969 Camaro SS 396 X66 Lemans Blue
1969 Corvette 427/390 Lemans Blue
Old 01-25-2019, 04:07 PM
No tubes......
The Following User Says Thank You to 69 Post Sedan For This Useful Post:
Rumbleguts396 (01-25-2019)
  #18
Old 04-14-2019, 10:51 PM
Hi Guys, just an update. I followed Kurt’s advice and went with M&H Racemaster Muscle Car Series tires size is P275/60-15. They are mounted on Cragar 15x8 with standard offset. Air shocks with extension bolts and a Shackle lift kit helped with the clearance. Not to mention the Day 2 look I was after. Thanks to all for your thoughts and input. Rob
The Following 6 Users Say Thank You to Rumbleguts396 For This Useful Post:
69 Post Sedan (04-14-2019), Damien (04-14-2019), L_e_e (04-14-2019), R68GTO (04-14-2019), RobR (04-15-2019), Spooky (04-14-2019)
  #19
Old 04-14-2019, 11:08 PM
Looks fantastic.......nice job!!!
Rumbleguts396 (04-14-2019)
  #20
Old 04-15-2019, 12:33 AM
Those match up nicely Rob. May I ask which front runners you guys are running?
