Old 06-03-2019, 12:01 AM
Default Repro Nova arm rest pads?
Delete...
Old 06-03-2019, 02:31 AM
Can you just get a used set of black pads and dye them? There are good vinyl dyes these days. Maybe try Just Dashes for color advise and dye in a spray can.
69 El Camino
69 Nova
C7 Vette
Old 06-03-2019, 02:38 AM
70post 70post is offline
Is the green vinyl the "metallic" or "pearl" type green color or just a "regular" green without that effect?
Patton Glade
70Post Restorations
Austin, TX
Old 06-03-2019, 02:54 AM
Smile Nova arm rest pads
Delete...
Old 06-03-2019, 03:14 AM
I believe that is the "metallic" or "pearl" type vinyl....very typical for the era but by '71 or 72 the green vinyls changed to the "regular" type vinyl.
Yes, "dye" is paint with some flex additives.
Another option is to find some new vinyl (call Legendary or PUI) in that color and have the pad recovered. I've recovered a lot of these pads in the past with new vinyl. Won't use repro pads for my customer's cars....most are fairly hideous (I'm referring to the pads, not my customer's cars!).
Legendary and/or PUI would likely sell you a half yard or yard of the correct grained vinyl. Color should be correct but can't guarantee if it will be slightly off due being new vinyl against aged original stuff. Pre-mixed vinyl paint in that color will have the same "effect" as new vinyl....a potential slight mismatch since it's mixed to the ORIGINAL finish/color. I spray a lot of vinyl paints/dyes.....doing some of the gold right now on some '70 442 interior pieces.
That pricing is a bit crazy but Just Dashes isn't known for low prices
EDIT: When I mention "pearl" or "metallic" in relation to this that is just MY labeling of the look....GM just called the colors "green", "blue", etc but prior to '71 or '72 the gold, blue and green vinyls had the "pearl" or "metallic" look I refer to. I also call them "Jetson's Blue", green, etc...since the effect is sort of a "space age" look.
Patton Glade
70Post Restorations
Austin, TX
Old 06-03-2019, 03:20 AM
Thumbs up Thank you!
Delete...
Old 06-03-2019, 03:22 AM
IMPORTANT - ask them to first send some swatches/samples as they may have some different choices....worth it even if they charge something for the samples.
Patton Glade
70Post Restorations
Austin, TX
The Following User Says Thank You to 70post For This Useful Post:
Arrowsmith (06-03-2019)
Old 06-04-2019, 01:36 PM
Smile Nova-Chevelle arm rest interchange?
Delete...
Old 06-04-2019, 05:13 PM
Therocknss Therocknss is offline
I also bought reproductions of my black arm rests and soon returned them because they were not correct. I noticed the material on them seems to match the material on my seats. When I recovered my seats I saved some good patches of that material. I was considering trying to recover them myself. Has nyone tried this?
Old 06-04-2019, 05:19 PM
delete...
