Old 06-22-2019, 01:30 PM
dlv4540 dlv4540 is online now
Default 1965-70 BBC Parts
1965 3855962 block dated E-27-5 standard bore and magged for cracks with a IE impala 396-425HP code on front stamping $3000.
ZL1 aluminum can am or yenko block casting number 3946052 and is a 4.40 standard bore tall deck block. Block has been pressure tested and is ready to build $8000.
1969 3919840 square port heads cleaned and magged and painted in primer sitting for awhile. The heads have been slightly ported and have oversized valves. Heads are dated J-30-8 & J-31-8 and come with all new hardware including stainless valves, 600 lift springs, retainers and a set of screw in studs and guide plates $1150.
1970 396-375HP engine standard bore block casting 3969854 dated H-20-9 with a CKO code. Block was cleaned, magged, pressure tested and fitted with two sleeves due to hairline cracks in cylinders #5 & #7. I have the 3964291 heads cleaned and magged dated F-6-9 & F-18-9, 6223 steel crank turned .010 under will need polished, 11 to 1 pistions with dimple rods with three of the rods non dimple and 8 inch harmonic balancer $3250.
1968-69 tripower fuel line goes from filter to carbs new with tag $35 and have a whole bunch of new line if someone wants to fit their own.
Manley double roller timing chain used for break in only $20.
427 deep high volume oil pump new $75
AC delco new in the box 195 degree thermostat #1623547 $10
blue streak cap and rotor new in the box $20
New set of AC delco spark plugs R43 & R44 $20 per box
New in box PF 25 ac delco oil filter $25
427 oil filter bypass $10
330-770-2517 for any questions and shipping not a problem if you cannot pick up.
Dennis Vugrinovich
The Following User Says Thank You to dlv4540 For This Useful Post:
Outlaw68Nova (06-27-2019)
Old 06-30-2019, 01:27 PM
bump
Dennis Vugrinovich
Old 07-20-2019, 02:01 PM
bump
Dennis Vugrinovich
Old 08-25-2019, 01:11 PM
Updated
Dennis Vugrinovich
Old 09-19-2019, 02:33 PM
Updated
Dennis Vugrinovich
Old 10-19-2019, 01:31 PM
bump
Dennis Vugrinovich
Old 11-11-2019, 01:50 PM
bump
Dennis Vugrinovich
Old 12-21-2019, 03:40 PM
Updated
Dennis Vugrinovich
